1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Report] EPICS R3.13.6 build on RH Linux7.3
Date: Mon, 24 Jun 2002 14:20:51 +0900
During the compilation of EPICS R3.13.6 base software on Red
Hat Linux 7.3 I encountered a couple of problem.
1) -UDEBUG_PRINT=0 option crashes gcc/cpp.
Makefile.Host in src/ca includes the line:
USR_CFLAGS += -UDEBUG_PRINT=0
This compiler option, -UDEBUG_PRINT=0, crashes gcc on RH
7.3. Acually any option of the form  "-U<macro>=<val>",
crashes gcc.
2) "int" instead of "osiSocklen_t" in
src/cas/io/bsdSocket/casIntfIO.cc.
In the file src/cas/io/bsdSocket/casIntfIO.cc,
a couple of variables are declared as "int" instead of
"osiSocklent_t". This causes "unable to promote "int" to
"socklent_t" " error with gcc on RH7.3.
We can avoid this error by declaring these variables
as osiSocklent_t.
*** io/bsdSocket/casIntfIO.cc   28 Sep 2000 10:50:45 -0000
    1.4
--- io/bsdSocket/casIntfIO.cc   24 Jun 2002 04:57:19 -0000
*** 70,76 ****
        int yes = TRUE;
        int status;
        caStatus stat;
!       int addrSize;
        if (!bsdSockAttach()) {
                return S_cas_internal;
--- 70,76 ----
        int yes = TRUE;
        int status;
        caStatus stat;
!       osiSocklen_t addrSize;
*** 223,229 ****
        struct sockaddr newAddr;
          SOCKET          newSock;
!         int             length;
        casStreamOS     *pOS;
          length = sizeof(newAddr);
--- 223,229 ----
          SOCKET          newSock;
!         osiSocklen_t    length;
        casStreamOS     *pOS;
Noboru
Prev: [Q] How to set a timestamp in a device support routine. Noboru Yamamoto
Next: Re: [Q] How to set a timestamp in a device support routine. Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: [Q] How to set a timestamp in a device support routine. David H. Thompson
Next: Re: [Report] EPICS R3.13.6 build on RH Linux7.3 Noboru Yamamoto
