1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Report] EPICS R3.13.6 build on RH Linux7.3
To: Janet Anderson <[email protected]>
Date: Tue, 25 Jun 2002 08:40:34 +0900
Janet Anderson wrote:
I can't find any Makefile.Host files in R3.13.* base with -UDEBUG_PRINT.
Janet
Woops. This was a local modification. I myself introduced it for debuggin purpose long before and forgot about it.
Please ignore this.
And also osiSocklen_t is already used in casIntfIO.cc.
Merging process of local modification with the EPICS distribution might overwrite these lines.
Sorry for waisting your valuable time with my previous e-mail. I appologize.
Noboru
Jeff Hill wrote:
Hi Noboru,
I am looking at the latest files (updated this morning) in my CVS
checkout of the R3.13 branch. These files should include changes made
for R3.13.6. In any case, I am seeing a mismatch compared to what you
are reporting so perhaps we are not looking at the same version in CVS?
Your item 1:
This -UDEBUG_PRINT=0 must be in base\src\sequencer, and not in
src/ca/Makefile.Host based on a quick search through the sequencer, and
so I will defer this one to Janet.
Your item 2:
It appears that these two "int" variable definitions have already (by
R3.13.6) been changed to "osiSocklen_t"?
Jeff
-----Original Message-----
Sent: Sunday, June 23, 2002 11:21 PM
To: [email protected]
Subject: [Report] EPICS R3.13.6 build on RH Linux7.3
During the compilation of EPICS R3.13.6 base software on Red
Hat Linux 7.3 I encountered a couple of problem.
1) -UDEBUG_PRINT=0 option crashes gcc/cpp.
Makefile.Host in src/ca includes the line:
USR_CFLAGS += -UDEBUG_PRINT=0
This compiler option, -UDEBUG_PRINT=0, crashes gcc on RH
7.3. Acually any option of the form  "-U<macro>=<val>",
crashes gcc.
2) "int" instead of "osiSocklen_t" in
src/cas/io/bsdSocket/casIntfIO.cc.
In the file src/cas/io/bsdSocket/casIntfIO.cc,
a couple of variables are declared as "int" instead of
"osiSocklent_t". This causes "unable to promote "int" to
"socklent_t" " error with gcc on RH7.3.
We can avoid this error by declaring these variables
as osiSocklent_t.
*** io/bsdSocket/casIntfIO.cc   28 Sep 2000 10:50:45 -0000
   1.4
--- io/bsdSocket/casIntfIO.cc   24 Jun 2002 04:57:19 -0000
*** 70,76 ****
       int yes = TRUE;
       int status;
       caStatus stat;
!       int addrSize;
       if (!bsdSockAttach()) {
               return S_cas_internal;
--- 70,76 ----
       int yes = TRUE;
       int status;
       caStatus stat;
!       osiSocklen_t addrSize;
*** 223,229 ****
       struct sockaddr newAddr;
         SOCKET          newSock;
!         int             length;
       casStreamOS     *pOS;
         length = sizeof(newAddr);
--- 223,229 ----
         SOCKET          newSock;
!         osiSocklen_t    length;
       casStreamOS     *pOS;
Noboru
Prev: Re: [Q] How to set a timestamp in a device support routine. Carl Lionberger
Next: genSub & PPC crash in dbProcess? Martin Pieck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Report] EPICS R3.13.6 build on RH Linux7.3 Noboru Yamamoto
Next: R3.13.6 bug report Jeff Hill
