1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: iocsh under Epics r3.14 RTEMS
To: [email protected]
Date: Wed, 10 Jul 2002 20:48:18 -0400
Hi all,
  I've come to an interesting impass in trying to get the example IOC to start
using R3.14.beta1 and RTEMS. I hope the problem is that I'me being simple..
      Drunig the boot sequence with rtems the Init() function is called from
rtems_init.c to setup the network, time , syslog etc. in Init() iocsh("st.cmd")
is called.
But Init() is called before main().
so the app specific iocRegester calls are never made, Sould I cuntomize
rtems_init.c for each app ?
or export a replacement iocshRegisterRTEMS() ?
Thanks.
Bill N.
[email protected]
The things you can't remember, tell the things you
can't forget.
Re: iocsh under Epics r3.14 RTEMS Till Straumann
Re: iocsh under Epics r3.14 RTEMS Eric Norum
Prev: Cross compiler source and patch file for gcc-2.7.2 on Linux David H. Thompson
Next: Re: iocsh under Epics r3.14 RTEMS Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Cross compiler source and patch file for gcc-2.7.2 on Linux dht
