Finally some RTEMS posting :-) Bill Nolan wrote: Hi all, I've come to an interesting impass in trying to get the example IOC to start I slightly patched rtems_init.c so it calls main(). Note that the appended patch also contains some other (small but important) fixes and workarounds useful under RTEMS - some things have already been fixed, I had been told, but probably are not in the distributed beta1 release yet. What CPU/BSP are you using? Regards -- Till
Index: RTEMS/base/rtems_init.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/RTEMS/base/rtems_init.c,v
retrieving revision 1.1.1.1
diff -c -r1.1.1.1 rtems_init.c
*** rtems_init.c 2002/03/09 18:09:24 1.1.1.1
--- rtems_init.c 2002/07/11 01:00:13
*** 193,204 ****
--- 193,213 ----
&rtems_bsdnet_config
+ #define DO_NORMAL_MAIN
* RTEMS Startup task
rtems_task
Init (rtems_task_argument ignored)
+ #ifndef DO_NORMAL_MAIN
+ /* T. Straumann: invoke global constructors
+ * from a task context...
+ extern void __do_global_ctors(void);
+ __do_global_ctors();
+ #endif
* Create a reasonable environment
*** 207,224 ****
putenv ("IOCSH_PS1=epics> ");
putenv ("IOCSH_HISTSIZE=20");
* Start network
printf ("***** Initializing network *****\n");
rtems_bsdnet_initialize_network ();
printf ("***** Initializing TFTP *****\n");
rtems_bsdnet_initialize_tftp_filesystem ();
for (;;) {
printf ("***** Initializing NTP *****\n");
if (rtems_bsdnet_synchronize_ntp (0, 0) >= 0)
break;
! epicsThreadSleep (10.0);
printf ("***** Initializing syslog *****\n");
openlog ("IOC", LOG_CONS, LOG_DAEMON);
--- 216,239 ----
+ /* T. Straumann: epicsThreadSleep() doesnt work before clockInit() */
+ clockInit();
* Start network
+ printf ("\nWelcome to EPICS on RTEMS\n");
for (;;) {
+ double sl=10.0;
break;
! printf("SLEEP %g\n",sl);
! epicsThreadSleep (sl);
*** 230,235 ****
--- 245,251 ----
printf ("***** Executing EPICS startup script *****\n");
iocshRegisterRTEMS ();
rtems_set_directory ();
+ #if 0
iocsh ("st.cmd");
*** 237,242 ****
--- 253,272 ----
epicsThreadSleep (2.0);
iocsh (NULL);
+ #else
+ #ifdef DO_NORMAL_MAIN
+ char *args[]={"iocsh","st.cmd"};
+ main(2,args);
+ #else
+ extern int rtems_main(int, char **);
+ rtems_main(2,args);
+ #endif
+ #endif
LogFatal ("Console command interpreter terminated");
Index: RTEMS/base/rtems_netconfig.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/RTEMS/base/rtems_netconfig.c,v
retrieving revision 1.2
diff -c -r1.1.1.1 -r1.2
*** rtems_netconfig.c 2002/03/09 18:09:24 1.1.1.1
--- rtems_netconfig.c 2002/03/09 19:08:38 1.2
*** 44,49 ****
--- 44,52 ----
#else /* Use NIC provided by BSP */
# define NIC_NAME RTEMS_BSP_NETWORK_DRIVER_NAME
# define NIC_ATTACH RTEMS_BSP_NETWORK_DRIVER_ATTACH
+ /* T. Straumann, TSILL, 12/18/2001, added declaration, just in case */
+ extern int
+ RTEMS_BSP_NETWORK_DRIVER_ATTACH();
#endif
static struct rtems_bsdnet_ifconfig netdriver_config = {
Index: libCom/cxxTemplates/tsFreeList.h
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/cxxTemplates/tsFreeList.h,v
*** tsFreeList.h 2002/03/09 18:09:30 1.1.1.1
--- tsFreeList.h 2002/04/05 00:52:34 1.2
*** 74,81 ****
template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u >
struct tsFreeListChunk {
! tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext;
tsFreeListItem < T, DEBUG_LEVEL > items [N];
--- 74,84 ----
! /* Till Straumann <[email protected]>, 2002/4/4
! * put the items first to maintain alignment.
+ tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext;
Index: libCom/osi/os/RTEMS/osdPoolStatus.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/osi/os/RTEMS/osdPoolStatus.c,v
*** osdPoolStatus.c 2002/03/09 18:09:31 1.1.1.1
--- osdPoolStatus.c 2002/03/09 18:38:31 1.2
*** 8,12 ****
--- 8,17 ----
epicsShareFunc int epicsShareAPI osiSufficentSpaceInPool ()
+ /* T. Straumann: 2/12/2002 the current RTEMS implementation
+ of this has a serious flaw (killing
+ real-time responsiveness!!!) DONT USE
return (malloc_free_space() > 100000);
+ return 1;
Index: libCom/osi/os/RTEMS/osdThread.c
RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/osi/os/RTEMS/osdThread.c,v
*** osdThread.c 2002/03/09 18:09:31 1.1.1.1
--- osdThread.c 2002/03/09 18:52:38 1.2
*** 118,131 ****
unsigned int
epicsThreadGetStackSize (epicsThreadStackSizeClass size)
switch(size) {
! case epicsThreadStackSmall: return( 4000*ARCH_STACK_FACTOR);
! case epicsThreadStackMedium: return( 6000*ARCH_STACK_FACTOR);
! case epicsThreadStackBig: return(11000*ARCH_STACK_FACTOR);
default:
errlogPrintf("epicsThreadGetStackSize illegal argument");
! return(11000*ARCH_STACK_FACTOR);
--- 118,136 ----
unsigned int
+ unsigned int rval=(11000*ARCH_STACK_FACTOR);
+ /* T. Straumann: make sure we allocate at least RTEMS_MINIMUM_STACK_SIZE */
switch(size) {
! case epicsThreadStackSmall: rval = ( 4000*ARCH_STACK_FACTOR); break;
! case epicsThreadStackMedium: rval = ( 6000*ARCH_STACK_FACTOR);
! case epicsThreadStackBig: break;
default:
+ break;
! if (rval < RTEMS_MINIMUM_STACK_SIZE)
! rval = RTEMS_MINIMUM_STACK_SIZE;
! return rval;
*** 261,267 ****
if (!initialized) epicsThreadInit();
if (stackSize < RTEMS_MINIMUM_STACK_SIZE) {
errlogPrintf ("epicsThreadCreate %s illegal stackSize %d\n",name,stackSize);
! return 0;
strncpy (c, name, sizeof c);
sc = rtems_task_create (rtems_build_name (c[0], c[1], c[2], c[3]),
--- 266,274 ----
! /* T. Straumann: just increase the stack size */
! /* return 0; */
! stackSize=RTEMS_MINIMUM_STACK_SIZE;
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
