I'm building this native-only version on solaris-sparc-gnu (Solaris 8).
The build faults on trying to build libcas.so , because the linker
complains about multiply-defined entry points, apparently from
caServerI.cc and casEventMask.cc . The detailed message from the
build is attached below.
As for my setup...
In CONFIG_SITE, I've turned on the build of dynamic libraries, and turned
off the build of vxworks targets.
In os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu, I add the following
overrides:
GNU_DIR = /usr/local
LD = /usr/ccs/bin/ld -r
DEPLIB_DIRS += /usr/local/lib
SHRLIB_LDFLAGS_YES = -Wl,-G -Wl,-dy
These are because our gcc/g++ is built to use Solaris as/ld instead of
the GNU binutils versions. (The last line overrides the default -share
in shared library builds, which would introduce -z text to ld in
addition to the desired -G and -dy . The -z text breaks the build
of libca.so .)
Other than those changes, it's the vanilla build system. The problem
is shown below. Can anybody help?
/usr/local/bin/g++ -o libcas.so.3.14 -Wl,-G -Wl,-dy -L/usr/local/lib -R/usr
/local/lib caServer.o caServerI.o casCoreClient.o casClient.o casDGClient.o
casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casPVListChan.o cas
ClientMon.o casChanDelEv.o casAsyncIOI.o casAsyncReadIO.o casAsyncWriteIO.o casA
syncPVExistIO.o casAsyncPVAttachIO.o casEventSys.o casMonitor.o casMonEvent.o in
Buf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o caServerOS.o casIntfOS.o casD
GIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::tableSize(void) const'
is multiply-defined:
(file caServerI.o and file casEventMask.o);
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::numEntriesInstalled(vo
id) const' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::operator=(resTable<cas
EventMaskEntry, stringId> const &)' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::lookup(stringId const
&) const' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::verify(void) const' is
multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::traverseConst(void (ca
sEventMaskEntry::*)(casEventMaskEntry const *) const) const' is multiply-defined
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::hash(stringId const &)
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::splitBucket(void)' is
multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::remove(stringId const
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::resTable(void)' is mul
tiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::~resTable(void)' is mu
ltiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::findDelete(tsSLList<ca
sEventMaskEntry> &, stringId const &)' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::find(tsSLList<casEvent
MaskEntry> &, stringId const &) const' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::traverse(void (casEven
tMaskEntry::*)(casEventMaskEntry *))' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::show(unsigned int) con
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::resTable(resTable<casE
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::add(casEventMaskEntry
&) ' is multiply-defined:
ld: fatal: File processing errors. No output written to libcas.so.3.14
collect2: ld returned 1 exit status
gmake[4]: *** [libcas.so.3.14] Error 1
gmake[4]: Leaving directory `/local/epics/r3.14.0Beta1/base/src/cas/build/O.sola
ris-sparc-gnu'
gmake[3]: *** [buildInstall.solaris-sparc-gnu] Error 2
gmake[3]: Leaving directory `/local/epics/r3.14.0Beta1/base/src/cas/build'
gmake[2]: *** [build.buildInstall] Error 2
gmake[2]: Leaving directory `/local/epics/r3.14.0Beta1/base/src/cas'
gmake[1]: *** [cas.buildInstall] Error 2
gmake[1]: Leaving directory `/local/epics/r3.14.0Beta1/base/src'
gmake: *** [src.buildInstall] Error 2
Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
RE: Cross compiler source and patch file for gcc-2.7.2 on Linux dht
<2002>
2025
2026
Re: iocsh under Epics r3.14 RTEMS Eric Norum
drvAscii Allan Honey
<2002>
2025
2026
