1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux
To: Brian McAllister <[email protected]>
Cc: [email protected]
Date: Fri, 12 Jul 2002 17:05:34 -0500
Brian McAllister wrote:
> >>> On 7/12/2002 at 16:40:49 CDT, Andrew Johnson wrote:
>   > EPICS 3.14 needs a fairly modern C++ compiler to compile - 2.7.2 is way
>   > too old.  You *will* have to use a version of gcc built from the
>   > official WRS sources, and Tornado 2.x when you want to upgrade to that
>   > (which is exactly where Ernest Williams and David Thompson came in with
>   > this problem).
> The version from WRS is still "2.7.2".
> Has WRS really hacked better C++ support into it, instead of migrating to
> the newer gcc ?
No, the WRS version is a combination of a gcc-2.7.2 C compiler back end
(modified by cygnus, probably with various bug fixes added), and later
versions of the G++ back end.  In Tornado 2.0 the C++ compiler was based
on EGCS 1.0.2, in the new Tornado 2.1 and 2.2 releases I believe it's
based on the Red-Hat gcc-2.96, or maybe something newer (not sure about
the Tornado 2.2 C compiler back-end).
I think WRS pay Red Hat to produce compiler versions to their
specification.  The problems Ernest and Dave wrestled with when they tried
to build a C++ cross-compiler from GNU sources were associated with name
mangling changes, and the fact that exception support is different for
each of these g++ versions.
- Andrew
Larry McVoy: "Learn how to think in C++ but don't ever program in it."
Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Brian McAllister
Prev: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Brian McAllister
Next: epics 3.14.0Base1 build problem Peter Kurpis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Cross compiler source and patch file for gcc-2.7.2 on Linux dht
