1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux
Cc: [email protected]
Date: Fri, 12 Jul 2002 17:51:32 -0400
>>> On 7/12/2002 at 16:40:49 CDT, Andrew Johnson wrote:
  > EPICS 3.14 needs a fairly modern C++ compiler to compile - 2.7.2 is way
  > too old.  You *will* have to use a version of gcc built from the
  > official WRS sources, and Tornado 2.x when you want to upgrade to that
  > (which is exactly where Ernest Williams and David Thompson came in with
  > this problem).
The version from WRS is still "2.7.2".
Has WRS really hacked better C++ support into it, instead of migrating to
the newer gcc ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Prev: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Next: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
