1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux
To: Brian McAllister <[email protected]>
Cc: "David H. Thompson" <[email protected]>, techtalk <[email protected]>
Date: Fri, 12 Jul 2002 16:40:49 -0500
Brian McAllister wrote:
> Did WRS make further changes which are needed for PPC, EPICS 3.14 or
> vxWorks 5.4 ?
EPICS 3.14 needs a fairly modern C++ compiler to compile - 2.7.2 is way
too old.  You *will* have to use a version of gcc built from the official
WRS sources, and Tornado 2.x when you want to upgrade to that (which is
exactly where Ernest Williams and David Thompson came in with this
problem).
- Andrew
Larry McVoy: "Learn how to think in C++ but don't ever program in it."
Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Brian McAllister
Prev: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Brian McAllister
Next: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
