1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux
To: "David H. Thompson" <[email protected]>
Cc: techtalk <[email protected]>
Date: Fri, 12 Jul 2002 17:28:55 -0400
>>> On 7/10/2002 at 16:01:50 EDT, David H Thompson wrote:
  > This is for those who are interested in the gcc-2.7.2 cross compiler
  > from Wind River that I discussed at the Epics meeting.
I built gcc-2.7.2.3 from the standard source distribution (not WRS), with
this configuration:
../configure --target=m68k-wrs-vxworks --prefix=/usr/local/vx/v53/host/Linux -program-prefix= -program-suffix=68k --with-gnu-as --with-gnu-ld --with-headers=/usr/local/vx/v53/target/h --with-libs=/usr/local/vx/v53/target/lib
echo host=i686-unknown-linux target=m68k-wrs-vxworks build=i686-unknown-linux
I have been using this on Redhat 7.0 to build EPICS 3.13.[1,2,4] for mv167
and mv177 targets loading vxWorks V5.3 kernels built with the official
Tornado 1.0 tools on Solaris.  I have had no problems.
I tried gcc-2.8.1 first, which produced code which would load, but not
execute.
I have not tried this with other target architectures, and the only C++
code built is what's in 3.13 base.
Did you try the standard gcc-2.7.2.3 ?
Did WRS make further changes which are needed for PPC, EPICS 3.14 or
vxWorks 5.4 ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Prev: Re: iocsh under Epics r3.14 RTEMS Eric Norum
Next: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Cross compiler source and patch file for gcc-2.7.2 on Linux David H. Thompson
