Mr. Bec
thanks for your advice
I did it according to your method except that
I set $EPICS/base/lib/Linux-x86 to my LD_LIBRARY_PATH,
but it still shows the the same errors,I don't know what to do.
anyway,thank you!
best regards
On Tue, 23 Jul 2002, Matthieu Bec wrote:
> Hi Zhao Zhuo,
> check your base/config/CONFIG_SITE for:
> SHARED_LIBRARIES=YES
> append $EPICS/base/lib/Linux to your LD_LIBRARY_PATH, and rebuild base
> to create libDb.so
> from there, you should be able to proceed.
> cheers,
> Matthieu
> Zhao Zhuo wrote:
> > hello,everyone!
> > I've built base_R3_14_0.alhpa_2,now I want to build GDCT that is included
> > in extensions313_2.So I did the following:
> > cd extensions/src/gdct313
> > make
> > but it shows the following informations:
> > make -C tools buildInstall
> > make[1]: Entering directory `/home/zz/extensions/src/gdct313/tools'
> > make -C O.linux-x86 -f ../Makefile.Host T_A=linux-x86 BUILD_TYPE=Host
> > buildInstall
> > make[2]: Entering directory
> > `/home/zz/extensions/src/gdct313/tools/O.linux-x86'
> > g++ -O -Wall -D_X86_ -Dlinux -DUNIX -I. -I..
> > -I../../../../include -I../../../../include/os/Linux
> > -I../../../../../extensions/include -I../../../../../base/include
> > -I../../../../../base/include/os/Linux -c ../dbedit.cc
> > ..../dbedit.cc: In method `void menu::PrintList (long int (*) (DBENTRY
> > *), long int (*) (DBENTRY *), char *(*) (DBENTRY *))':
> > ..../dbedit.cc:206: warning: comparison between signed and unsigned
> > integer expressions
> > ..../dbedit.cc: In method `int menuMain::Command (char)':
> > ..../dbedit.cc:238: warning: suggest parentheses around assignment used
> > as truth value
> > ..../dbedit.cc: In function `int main (int, char **)':
> > ..../dbedit.cc:465: warning: unused variable `int j'
> > ..../dbedit.cc:465: warning: unused variable `int state'
> > ..../dbedit.cc:465: warning: unused variable `int i'
> > ..../dbedit.cc:465: warning: unused variable `int s'
> > ..../dbedit.cc:466: warning: unused variable `char *rname'
> > ..../dbedit.cc:466: warning: unused variable `char *pc'
> > ..../dbedit.cc: In function `char *ResolveName (char *)':
> > ..../dbedit.cc:543: warning: unused variable `int i'
> > g++ -o dbedit -O -Wall -D_X86_ -Dlinux -DUNIX -I. -I..
> > -L../../../../../base/lib/linux-x86/ -lpthread -lreadline -lcurses -lrt
> > dbedit.o -lDb -lCom -lm
> > /usr/bin/ld: cannot find -lDb
> > collect2: ld returned 1 exit status
> > make[2]: *** [dbedit] Error 1
> > make[2]: Leaving directory
> > make[1]: *** [buildInstall.linux-x86] Error 2
> > make[1]: Leaving directory `/home/zz/extensions/src/gdct313/tools'
> > make: *** [tools.buildInstall] Error 2
> > I don't know how to solve it,who can help me?
> > thanks in advance!
> > best regards!
- Re: buiding GDCT Maren Purves
- Re: Matthieu Bec
Re: Problem of ChannelArchive Thomas . Birke
Re: ISEG VHQ204L Driver ahed aladwan
<2002>
2025
2026
Re: Matthieu Bec
<2002>
2025
2026
