Hi Zhao Zhuo,
check your base/config/CONFIG_SITE for:
SHARED_LIBRARIES=YES
append $EPICS/base/lib/Linux to your LD_LIBRARY_PATH, and rebuild base
to create libDb.so
from there, you should be able to proceed.
cheers,
Matthieu
Zhao Zhuo wrote:
> hello,everyone!
> I've built base_R3_14_0.alhpa_2,now I want to build GDCT that is included
> in extensions313_2.So I did the following:
> cd extensions/src/gdct313
> make
> but it shows the following informations:
> make -C tools buildInstall
> make[1]: Entering directory `/home/zz/extensions/src/gdct313/tools'
> make -C O.linux-x86 -f ../Makefile.Host T_A=linux-x86 BUILD_TYPE=Host
> buildInstall
> make[2]: Entering directory
> `/home/zz/extensions/src/gdct313/tools/O.linux-x86'
> g++ -O -Wall -D_X86_ -Dlinux -DUNIX -I. -I..
> -I../../../../include -I../../../../include/os/Linux
> -I../../../../../extensions/include -I../../../../../base/include
> -I../../../../../base/include/os/Linux -c ../dbedit.cc
> ..../dbedit.cc: In method `void menu::PrintList (long int (*) (DBENTRY
> *), long int (*) (DBENTRY *), char *(*) (DBENTRY *))':
> ..../dbedit.cc:206: warning: comparison between signed and unsigned
> integer expressions
> ..../dbedit.cc: In method `int menuMain::Command (char)':
> ..../dbedit.cc:238: warning: suggest parentheses around assignment used
> as truth value
> ..../dbedit.cc: In function `int main (int, char **)':
> ..../dbedit.cc:465: warning: unused variable `int j'
> ..../dbedit.cc:465: warning: unused variable `int state'
> ..../dbedit.cc:465: warning: unused variable `int i'
> ..../dbedit.cc:465: warning: unused variable `int s'
> ..../dbedit.cc:466: warning: unused variable `char *rname'
> ..../dbedit.cc:466: warning: unused variable `char *pc'
> ..../dbedit.cc: In function `char *ResolveName (char *)':
> ..../dbedit.cc:543: warning: unused variable `int i'
> g++ -o dbedit -O -Wall -D_X86_ -Dlinux -DUNIX -I. -I..
> -L../../../../../base/lib/linux-x86/ -lpthread -lreadline -lcurses -lrt
> dbedit.o -lDb -lCom -lm
> /usr/bin/ld: cannot find -lDb
> collect2: ld returned 1 exit status
> make[2]: *** [dbedit] Error 1
> make[2]: Leaving directory
> make[1]: *** [buildInstall.linux-x86] Error 2
> make[1]: Leaving directory `/home/zz/extensions/src/gdct313/tools'
> make: *** [tools.buildInstall] Error 2
> I don't know how to solve it,who can help me?
> thanks in advance!
> best regards!
Matthieu Bec Gemini Observatory
Tel: +1 808 9742557 670 N. A'ohoku Place
Fax: +1 808 9359235 Hilo, Hawaii 96720, USA
- Re:buiding GDCT Zhao Zhuo
- [no subject] Zhao Zhuo
about building GDCT Zhao Zhuo
Problem of ChannelArchive Cheng Weixing@ssrc
<2002>
2025
2026
<2002>
2025
2026
