1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem of ChannelArchive
To: "Kay-Uwe Kasemir" <[email protected]>
Cc: "Tech talk EPICS" <[email protected]>
Date: Wed, 24 Jul 2002 12:18:47 +0800
Dear Sir,
I have encounted a problem of recording channels while using ChannelArchive(version 1.7.1).
QDR1:INT-AVG ; QDR1:X-AVG ; QDR1:Y-AVG are three ai record, they all scanned at a period of 1 second.And I can use MEDM to monitor these channels,it's working well.
While I try to use channelArchiver to record these channel, it seems there have some problems. I have tried to use different config files, but none of them worked. Here is what I have done:
1. step 1.
edit the epics.cfg file ,including these lines to archive 3 channels.
QDR1:INT-AVG
QDR1:X-AVG
QDR1:Y-AVG
then start to record the channels using command:
$ArchiveEngine epics.cfg dbpm_data_dir
and I can view and config the channels http://localhost:4812/
Waiting for several minutes, using http://localhost:4812/stop to end the
archiver
Using ArchiveExport to export the archived dbpm_data_dir:
$ArchiveExport -text -output dbpm_data dbpm_data_dir
the contents of dbpm_data is like this:
Time QDR1:INT-AVG [digits] Status QDR1:X-AVG [mm] Status QDR1:Y-AVG [mm] Status
7/24/2002 11:05:11.024723023 5073   0.0286811   0.00344885
7/24/2002 11:05:12.000000000 5073   0.0286811   0.00344885
7/24/2002 11:05:13.000000000 5073   0.0286811   0.00344885
7/24/2002 11:05:14.000000000 5073   0.0286811   0.00344885
7/24/2002 11:05:15.000000000 5073   0.0286811   0.00344885
7/24/2002 11:05:16.000000000 5073   0.0286811   0.00344885
7/24/2002 11:05:17.000000000 5073   0.0286811   0.00344885
The value of these three channels never changed?
2. step 2.
change epics.cfg to :
QDR1:INT-AVG 1 Monitor
QDR1:X-AVG 1 Monitor
QDR1:Y-AVG 1 Monitor
follow the operation as in step 1.
The exported dbpm_data:
7/24/2002 11:15:04.014441653 5071   0.0286927   0.00266235
no matter how long lasted, there have only one line in the file.
3. step 3.
Using 5 seconds scan in epics.cfg:
QDR1:INT-AVG 5
QDR1:X-AVG 5
QDR1:Y-AVG 5
And now the contents of dbpm_data is :
7/24/2002 11:18:53.011652405 5072   0.0284897   0.00256317
7/24/2002 11:18:55.000000000 5072   0.0284897   0.00256317
7/24/2002 11:19:00.000000000 5072   0.0284897   0.00256317
7/24/2002 11:19:05.000000000 5072   0.0284897   0.00256317
7/24/2002 11:19:10.000000000 5072   0.0284897   0.00256317
7/24/2002 11:19:15.000000000 5072   0.0284897   0.00256317
7/24/2002 11:19:20.000000000 5072   0.0284897   0.00256317
It is similar to step1.
4. step 4.
Set epics.cfg to 5 seconds monitor:
QDR1:INT-AVG 5 Monitor
QDR1:X-AVG 5 Monitor
QDR1:Y-AVG 5 Monitor
the export dbpm_data is like this:
7/24/2002 11:22:27.007671187 5076   0.0291571   0.00354628
(Note:between different steps, I have deleted the old dbpm_data and dbpm_data_dir. so the new output file dbpm_data have no relationship with the old one)
We can see that the channel value changed in different steps, but it can't record the correct value for individual step. I don't know what's wrong with it, can you help me?
BTW: I can use ChannelArchive to record the example channel "$(USER):aiExample" or "$(USER):calcExample". it works very well while include these two channels. And also they scaned at a period of 1 second, so I really amazing about it.
Best Regards,
Cheng Weixing
P.O. Box 800-204,Shanghai, P.R.China 201800
Beam Instrumentation Group, SSRF
Email: [email protected]
Tel:(86-21)5955 3998-Ext449
Re: Problem of ChannelArchive Thomas . Birke
Prev: Re: Matthieu Bec
Next: Re: Problem of ChannelArchive Thomas . Birke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Janet Anderson
