For this problem of forcing instructions to occur in the order that
they appear in the code, I've used the asm instructions as well. To make
maintenance a bit easier I defined macros. Some but not all bsp's come with these
macros already. If not in a header file you may find it in some of the vxWorks source
for a bsp.
#define EIEIO __asm__ volatile ("eieio")
#define EIEIO_SYNC __asm__ volatile ("eieio;sync")
#define SYNC __asm__ volatile ("sync")
Can you please send any fixes to the code back to me so that I can add these changes.
- Regards,
Kristi
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Thursday, July 25, 2002 9:14 AM
> To: Kay-Uwe Kasemir
> Cc: Burkhard W. Kolb; [email protected]
> Subject: Re: ISEG VHQ204L Driver (Really: PPC and VME)
> Kay-Uwe Kasemir wrote:
> > Sounds like another way of forcing electrons out of the CPU
> > - if not even better than __asm__ volatile ("sync").
> eieio is likely to be quicker - IIRC the sync causes the instruction
> pipeline to be stalled until the write is done as well, which isn't
> strictly necessary in this case (but useful when installing new CPU
> instructions).
> > But what about the Universe II chip on most PPC boards
> > which has its own write pipeline?
> > Is there a "flush" register/command on it?
> IIRC there's a bit somewhere that claims to show whether the write
> pipeline is empty, but when I tried putting code into the Universe
> interrupt handler to wait for this after running each ISR it made no
> difference to the "bad vme interrupt 0" error messages we
> were getting.
> The dummy read is the correct technique, as it also works on
> the Motorola
> 68K boards that have a VMEchip2 if that's set to do write pipelining.
> > (2) the fact that the memory regions mapped to VME are
> configured as "not cacheable"
> > in the vxWorks BSP's sysPhysMemDesc
> BTW, I also mark our VME regions as Guarded, which supposedly
> prevents the
> CPU from changing the order of writes to that address region. I'm not
> sure if it makes any difference IRL, but it certainly makes me happier
> after having read about the possibility.
> - Andrew
> Larry McVoy: "Learn how to think in C++ but don't ever program in it."
epicsBase3.13.7 Marty Kraimer
GPIB driver & device support update Benjamin Franksen
<2002>
2025
2026
building SDDS.1.21.1 on Solaris 2.8 Lei Ge
<2002>
2025
2026
