This might not be the same problem that Bernard is having, but I am using
cygwin which generates different paths than the standard windows paths. In
order to make it possible for the microsoft compiler and loader to find the
includes and libraries I did the following:
I put these definitions in my .bashrc file:
export HOST_ARCH=WIN32
export EPICS_BASE=/home/Rozelle/epicsDvl/base-3.14.beta1
export DOS_EPICS_BASE=C:/cygwin$EPICS_BASE
alias makeMyAppl="perl $EPICS_BASE/bin/$EPICS_HOST_ARCH/makeBaseApp.pl -b
$DOS_E
PICS_BASE -t example test"
alias makeMyIocAppl="perl $EPICS_BASE/bin/$EPICS_HOST_ARCH/makeBaseApp.pl
-b $DO
S_EPICS_BASE -i -t example test"
I have the aliases makeMyAppl and makeMyIocAppl to remind me what
parameters work. I would of course change the name of the application from
test to something else for a real application.
If I left out the -b parameter, makeBaseApp.pl would define
EPICS_BASE as /home/Rozelle/epicsDvl/base-3.14.beta1
with the -b parameter it becomes
EPICS_BASE=C:/cygwin/home/Rozelle/epicsDvl/base-3.14.beta1
which allows the compiler and loader to find includes and libraries.
Perhaps this will help.
Rozelle
At 06:56 AM 8/8/2002 -0500, Marty Kraimer wrote:
This looks like a problem with WIN32. I do not use windows so I can't
help. Here at APS Janet does test on windows so she will be able to help
but is on vacation until next Monday.
In the meantime can some other windows user help?
Sorry I could not help.
Marty Kraimer
Bernhard Kuner wrote:
Hallo,
there seems to be a problem with the baseR3.14.0beta2 make files and
scripts. I try to develope a driver support and run into this problems:
1. There ist no include path to the base!
I created an application - a new top - with makeBaseApp.pl and set in
configure/RELEASE: EPICS_BASE=C:/project/epics/baseR3.14.0beta2
but it is impossible to include any .h file form the base! I found the
not very elegant solution to set it in the makefile:
USR_INCLUDES = -I C:\\project\\epics\\baseR3.14.0beta2\\include -I
C:\\project\\epics\\baseR3.14.0beta2\\include\\os\\WIN32
Is there a better way? Did I make anything wrong?
2. There is an error in the automagic created
opc_registerRecordDeviceDriver.cpp
The opc.dbd it contains only this:
include "aiRecord.dbd"
device(ai,INST_IO,devOpc,"opc")
It will be parsed and in the file opc_registerRecordDeviceDriver.cpp are
empty entries. The compiler doesn't like this
static const char * const deviceSupportNames[2] = {
"devOpc"
static const struct dset * const devsl[2] = {
&devOpc
extern "C" struct drvet ;
extern "C" struct drvet drvOpc;
static char *driverSupportNames[2] = {
"drvOpc"
static struct drvet *drvsl[2] = {
&drvOpc
best regards (gruessle)
- driver developement for baseR3.14.0beta2 Bernhard Kuner
- Re: driver developement for baseR3.14.0beta2 Marty Kraimer
FW: Application for port-number (5064-5065) Jeff Hill
beware PATH pitfall when upgrading from 3.14.beta1 to 3.14.beta2 on Win32- Rozelle Wright
<2002>
2025
2026
Recommend VME analog input board w/filtering? John A. Priller
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
