1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to device support debugging vars via iocsh (3.14b2)
To: Eric Norum <[email protected]>
Cc: "S. Joshua Stein" <[email protected]>, [email protected]
Date: Tue, 20 Aug 2002 12:10:05 -0700
Eric Norum wrote:
I should also point out that Til Strauman <[email protected]> has implemented a full C-expression parser + lookup utility for
RTEMS. I've not had time to see how hard it would be to integrate this into iocsh.
Well this should not be too hard. However, there are a few things:
- licensing issues. It seems that migrating to the new license is very complicated
for SLAC. We're not there yet. Plus, I don't know if I can release 'cexp' under
the EPICS open license or the LGPL. I have no clue who would have to give
the respective authorization.
- cexp currently only supports ELF. However, I am working on using BFD
  instead of libelf, which has several advantages:
  - support for more binary formats
  - implementing a runtime loader should be easy
  - we get a disassembler for free
  As a matter of fact, I am pretty close to having an alpha version.
- instead of integrating cexp into iocsh, it might be easier to keep the utilities
separate (cexp is also targetted for plain RTEMS systems without EPICS).
I simply register cexp with the iocsh and hence can switch between both .
-- Till
I keep hoping that Til will get tired of waiting for me and merge this himself :-)
-- Eric Norum <[email protected]> Department of Electrical Engineering University of Saskatchewan Saskatoon, Canada. Phone: (306) 966-5394 FAX: (306) 966-5407
Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
Prev: Re: FW: Application for port-number (5064-5065) Bob Dalesio
Next: subRecord fix Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
Next: Capfast Symbol for Motor Record Porter, Rodney
