Does your application call gettimeofday to get the time stamp?
If so it uses seconds since the UNIX epoc (1970) and microseconds within the
second. Another, less likely, possibility is that your application calls
clock_gettime, which uses seconds since the POSIX epoch (1970) and nanoseconds
within the second. Another possibility is that your application calls time which
just returns seconds since 1970.
For EPICS call tsLocalTime for 3.13 or for 3.14 call epicsTimeGetCurrent.
Marty Kraimer
Kevin Tsubota wrote:
Hi All,
I have a channel access application that we inherited from someone else a
long time ago that is
returning a timestamp of seconds since 1/1/1970. This application also has
its own camonitor
utility that returns the current date. However when I use the base
camonitor I get timestamps 20yrs
in the future.
Upon further investigation I found comments that EPICS uses 1/1/1990 as its
epoch. So I'm guessing
here that EPICS camonitor is taking the timestamp from my application and
adding 20yrs. Is this
correct or am I _way_ out in left field?
Thanks in advance.
Kevin
Code snippet from EPICS R3.13.0Beta12/base/include/tsDefs.h
* TS_STAMP
* This is the form taken by time stamps in GTACS, and is the form used
* by the various tools used for dealing with time stamps.
* The time stamp represents the number of nanoseconds past 0000 Jan 1,
199
0,
* GMT (or UTC, if you prefer).
typedef struct {
epicsUInt32 secPastEpoch; /* seconds since 0000 Jan 1, 1990 */
epicsUInt32 nsec; /* nanoseconds within second */
} TS_STAMP;
- timestamp question Kevin Tsubota
RE: timestamp question Jeff Hill
<2002>
2025
2026
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
