Pedro,
> CAC: Unable to connect port 5064 on "10.2.2.106:5064"
> because 22="S_errno_EINVAL"
> dbCa:exceptionCallback stat Network connection lost channel unknown
This looks like a benign glitch in EPICS R3.13. It appears that one
thread called the connect() system call briefly after another thread
closed the socket.
Your observation that a hard reboot fixed the problem, and a soft reboot
did not, does not immediately point to a software problem.
Have you seen this situation occur more than once? Which version of
EPICS was running?
Jeff
--- Begin Message ---
Title: S_errno_EINVAL
Can someone tell me what the following error message means:
CAC: Unable to connect port 5064 on "10.2.2.106:5064" because
22="S_errno_EINVAL"
10.2.2.106 is the IP of another crate where the system is supposed to
get a value. The system did not work properly when rebooted with a
CTRL-X, but it started to work fine after a hard reset.
Pedro.
--- End Message ---
- S_errno_EINVAL Pedro Gigoux
RE: FILETIME to epicsTimeStamp Jeff Hill
pprsyd library and header files for cau? Dale L. Brewe
<2002>
2025
2026
<2002>
2025
2026
