1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Recommendations for Power PC VME cards
To: Dennis Armstrong <[email protected]>
Cc: "Tech Talk (EPICS)" <[email protected]>
Date: Thu, 19 Sep 2002 16:36:56 -0500
Hi Dennis,
Dennis Armstrong wrote:
We are considering an upgrade to our systems to use the Power PC range
of VME CPU cards .  So the  question is  which VME CPU cards do EPICS
users  use?
APS have experience with the MVME2700 and MVME2100 boards, and we're in the process of getting the MVME5100 for some applications. The latter family appears to be where Motorola are concentrating their development efforts, although the other lines aren't likely to be closed out anytime soon. To use the 5100 series you'll need Tornado 2.1 or 2.2, whereas the older boards can be used with earlier versions even back to T1.0.1 (not that I'd recommend that though).
You should look at your I/O requirements for the CPU board - if you don't need more serial ports and other I/O then don't pay extra for stuff you don't need. The MVME2100 is a low-cost board which is slightly slower than the 2300/2400/2600/2700 devices but works fine for most purposes.
Which are most compatible with the EPICS software?
In general EPICS compatibility isn't likely to be a problem for almost any PowerPC CPU. There may be some changes you might want/need to make to the BSP to get some drivers going, but most devices Just Work™ (as long as you're using EPICS R3.13.6 or later).
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
Recommendations for Power PC VME cards Dennis Armstrong
Prev: Re: old/new MVME-177 compatability Andrew Johnson
Next: RE: Recommendations for Power PC VME cards Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Recommendations for Power PC VME cards Korhonen Timo
Next: Re: Recommendations for Power PC VME cards Till Straumann
