1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Making CA calls from multi-threaded programs???
To: [email protected]
Date: Sun, 22 Sep 2002 21:30:50 -0700 (PDT)
Hello,
I am developing sequencing code using a case tool called
Rhapsody.  This is part of the Keck Interferometer control
system and talks to EPICS PVs via a Keck Keyword API layer on
top of Channel Access.  I assume the Keyword API is built
on the portable CA libraries.  Currently running EPICS
3.13.0 Beta 12 at Keck and I assume the Keyword library
is linked to this.  Well up until now my Keywords (PVs) where used
in two threads and seemed to work just fine.  But I had
to add a keyword to a third thread and the following error
message is given:
CAC: unexpected select fail: 9=Bad file number
Segmentation fault
And my program segment faulted as shown.  Found this
message in $EPICS/base/src/ca/bsd_depen.c.  It is not
that the code does not run but rather this happens after
the code is running for a few minutes.  Any ideas about
exactly what is going on here?  Could an upgrade of EPICS
help this situation?
Len
Re: Making CA calls from multi-threaded programs??? Christopher Larrieu
Prev: Another SPARC alignment bug in 3.14_beta1 Till Straumann
Next: Re: Making CA calls from multi-threaded programs??? Christopher Larrieu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Another SPARC alignment bug in 3.14_beta1 Jeff Hill
