You probably fixed this one already - RSRV on SPARC dies with SIGBUS on putNotify due to a misaligned buffer. Just to make sure, there's a patch attached (3.14_beta1)... -- Till Index: camessage.c
RCS file: /afs/slac/g/spear/cvsrep//epics/base/src/rsrv/camessage.c,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -c -r1.1.1.1 -r1.2
*** camessage.c 2002/03/09 18:09:35 1.1.1.1
--- camessage.c 2002/09/19 23:52:08 1.2
*** 1548,1555 ****
--- 1548,1568 ----
* block if it is to small
if(pciu->pPutNotify->valueSize<size){
+ #ifdef MISALIGNED_BUFFER
free(pciu->pPutNotify);
pciu->pPutNotify = NULL;
+ #else
+ free(pciu->pPutNotify->dbPutNotify.pbuffer);
+ pciu->pPutNotify->valueSize = 0;
+ pciu->pPutNotify->dbPutNotify.pbuffer = casCalloc(1,size);
+ if (!pciu->pPutNotify->dbPutNotify.pbuffer) {
+ log_header ( "no memory to initiate put notify",
+ client, mp, pPayload, 0 );
+ putNotifyErrorReply (client, mp, ECA_ALLOCMEM);
+ return RSRV_ERROR;
+ pciu->pPutNotify->valueSize = size;
+ #endif
*** 1559,1573 ****
--- 1572,1598 ----
if(!pciu->pPutNotify){
pciu->pPutNotify = (RSRVPUTNOTIFY *)
casCalloc(1, sizeof(*pciu->pPutNotify)+size);
+ #else
+ casCalloc(1, sizeof(*pciu->pPutNotify));
+ if (pciu->pPutNotify)
+ #endif
+ #else
+ if(!pciu->pPutNotify || !pciu->pPutNotify->dbPutNotify.pbuffer){
+ #endif
return RSRV_ERROR;
pciu->pPutNotify->dbPutNotify.pbuffer = (pciu->pPutNotify+1);
+ #endif
pciu->pPutNotify->dbPutNotify.usrPvt = pciu;
pciu->pPutNotify->dbPutNotify.paddr = &pciu->addr;
pciu->pPutNotify->dbPutNotify.userCallback = write_notify_call_back;
*** 1758,1763 ****
--- 1783,1792 ----
if (pciu->pPutNotify) {
+ #else
+ free (pciu->pPutNotify->dbPutNotify.pbuffer);
+ #endif
free (pciu->pPutNotify);
Index: caservertask.c
RCS file: /afs/slac/g/spear/cvsrep//epics/base/src/rsrv/caservertask.c,v
*** caservertask.c 2002/03/09 18:09:35 1.1.1.1
--- caservertask.c 2002/09/19 23:52:08 1.2
*** 587,592 ****
--- 587,596 ----
status = db_flush_extra_labor_event (client->evuser);
assert (status==DB_EVENT_OK);
+ #else
+ #endif
LOCK_CLIENTQ;
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
