1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: is there a way to get caRepeater statistics
To: Kevin Tsubota <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 23 Oct 2002 10:27:24 +0200
Hi Kevin,
there are no statistics available from the caRepeater. Sorry.
Also, your description sounds as if you rather need to have debug
information about the current status than statistics, which usually are
numbers and rates collected over a long time span.
You can always compile the caRepeater with '-DDEBUG' which will make it
blurp about all kinds of things.
You should also have a look at the casw command line utility, which is
part of Channel Accesss (documented in the CA manual).
Hope this helps,
Ralph
>>>>> "Kevin" == Kevin Tsubota <[email protected]> writes:
  > Hi All,
  > Is there a way to get statistics from a running caRepeater?
  > We've upgraded our hosts from solaris-6 to solaris-8 and have been
  > experiencing
  > frequent channel access disconnects for no apparent reason.  I'd like to
  > find out what
  > caRepeater has been doing / what its connected to, etc.
  > We're still running EPICS R3.13.0beta12 built on solaris-6, yes you're
  > reading
  > correctly... we're running solaris-six built EPICS on solaris-eight.
  > Forturnately
  > everything works, or so it seems anyway.
  > We do plan to upgrade to EPICS R3.13.6 or later one day. Has that day come?
  > Thanks in advance.
  > Kevin Tsubota
  > W.M. Keck Observatory
is there a way to get caRepeater statistics Kevin Tsubota
Prev: is there a way to get caRepeater statistics Kevin Tsubota
Next: RE: is there a way to get caRepeater statistics Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
