My mistake, the error is ECA_DISCONN (which makes more sense)
and not ECA_ANACHRONISM (I shifted the value twice instead
of 3 times).
And, no, I'm not calling CA from a multi-threaded application.
John
On Tue, 29 Oct 2002, Jeff Hill wrote:
> John,
> > examine args.status
> > // status here is sometimes ECA_ANACHRONISM
> > Has this always been possible?
> I think you are asking if CA will set the status
> field in the event_handler_args structure to
> ECA_ANACHRONISM. The answer is no. I searched
> all of the source code in the latest versions of
> R3.13 and R3.14 and ECA_ANACHRONISM is returned
> only when you call a very old CA interface from
> R3.11 or probably earlier that is no-longer
> supported.
> Are you calling CA from a multi-threaded
> application?
> Jeff
> > -----Original Message-----
> > From: john sinclair [mailto:[email protected]]
> > Sent: Tuesday, October 29, 2002 10:48 AM
> > To: tech talk
> > Subject: CA error
> > One stress test I have applied to edm is performing a moderately rapid
> > succession of connects/disconnects via a channel access server.
> > I have recently noticed one problem.
> > The logical code structure is shown below:
> > global needInit
> > main routine:
> > needInit = false
> > search_and_connect
> > do {
> > pend io, event
> > if ( needInit ) { // needInit is set in the connect callback
> > ca_get_callback(...)
> > needInit = false
> > } until all outstanding io is complete
> > connect_callback function (...) {
> > if ( pv is connected ) {
> > needInit = true
> > else {
> > needInit = false
> > get_callback function (
> > struct event_handler_args args
> > examine args.status
> > // and args.dbr is NULL
> > Has this always been possible? I'm sure I get the connect callback
> > before
> > the get callback (by examining other data that gets set in the connect
> > callback {not shown in above simplified example}).
> > John Sinclair
> > [email protected]
> > Oak Ridge National Lab
> > 865-576-6362 865-574-1268 (fax)
John Sinclair
[email protected]
- RE: CA error Jeff Hill
Simatic PLCs Rolf Keitel
<2002>
2025
2026
<2002>
2025
2026
