John,
> examine args.status
> // status here is sometimes ECA_ANACHRONISM
> Has this always been possible?
I think you are asking if CA will set the status
field in the event_handler_args structure to
ECA_ANACHRONISM. The answer is no. I searched
all of the source code in the latest versions of
R3.13 and R3.14 and ECA_ANACHRONISM is returned
only when you call a very old CA interface from
R3.11 or probably earlier that is no-longer
supported.
Are you calling CA from a multi-threaded
application?
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Tuesday, October 29, 2002 10:48 AM
> To: tech talk
> Subject: CA error
> One stress test I have applied to edm is performing a moderately rapid
> succession of connects/disconnects via a channel access server.
> I have recently noticed one problem.
> The logical code structure is shown below:
> global needInit
> main routine:
> needInit = false
> search_and_connect
> do {
> pend io, event
> if ( needInit ) { // needInit is set in the connect callback
> ca_get_callback(...)
> needInit = false
> } until all outstanding io is complete
> connect_callback function (...) {
> if ( pv is connected ) {
> needInit = true
> else {
> needInit = false
> get_callback function (
> struct event_handler_args args
> examine args.status
> // and args.dbr is NULL
> Has this always been possible? I'm sure I get the connect callback
> before
> the get callback (by examining other data that gets set in the connect
> callback {not shown in above simplified example}).
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362 865-574-1268 (fax)
- RE: CA error john sinclair
- CA error john sinclair
CA error (fwd) john sinclair
<2002>
2025
2026
<2002>
2025
2026
