Yes - that's a frequent problem.
Apart from pointing out that the future might bring freedom of this
limitation...
.... well, you might also be able to use a technique similar to what I
described to Rok Sabjan in July, which is actually quite close to Ned's
first suggestion.
http://www.aps.anl.gov/epics/tech-talk/2002/msg00393.php
Ralph
>>>>> "Ned" == Ned Arnold <[email protected]> writes:
> This has come up often ...
> The MBBO record is limited to 16 values because all
> enumerated values passed by channel access are limited
> to 16 states (MAX_ENUM_STATES). If this is changed, everything
> breaks.
> There aren't any "perfect" work arounds. Here are two I have
> seen used:
> 1) If you want strings on a menu, define multiple MBBO's to
> cover as many as you need. A unique value can be calculated
> in the database depending on which MBBO changed. Unfortunately,
> all clients that want to use these PVs will have to decide which
> PV to write to.
> For an operator GUI, a TCL/TK application can be written that
> provides ALL menu choices and writes to the appropriate PV.
> 2) If you can do without strings, use a longout record that can
> then fanout to calc records and mbbo's to determine the
> appropriate action.
> Ned
- Re: Extending MBBO? Ned Arnold
Re: Extending MBBO? Brian McAllister
<2002>
2025
2026
<2002>
2025
2026
