1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Extending MBBO?
To: [email protected]
Date: Thu, 07 Nov 2002 12:34:51 -0500
>>> On 11/7/2002 at 11:15:21 CST, Ned Arnold wrote:
  > 2) If you can do without strings, use a longout record that can then
  > fanout to calc records and mbbo's to determine the appropriate action.
If the selection you want is done by setting 22 individual *bits* (rather
than 22 *values*), there should be an alternative using the mbboDirect
record, working through the fields for the individual bits.
Unfortunately, when mbboDirect was created from mbbo, VAL was defined as
DBF_USHORT, instead of DBF_ULONG, and only 16 bit fields were added.  I've
thought about adding another 16 bit fields (using B10 -> B1F so the
existing field names don't have to change), but I'm not sure of the
consequences of changing VAL from SHORT to LONG for existing clients.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: Extending MBBO? Ned Arnold
Prev: Re: Extending MBBO? Ralph Lange
Next: Use of AutoReply Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Extending MBBO? Owens, PH (Peter)
