> I executed this command on my linux system,
> locate libreadline
> it is showing that two packages installed at,
> /usr/lib/libreadline.so.4
> /usr/lib/libreadline.so.4.2
> Do I have to still install this package or is it the
> problem with .so package. Do we need .a package
> installed in the system instead of this package.
Hi Vijayram,
this readline library should be sufficient.
Hmmm ...
.... might be that the loader library cache on your Linux box is not set
up correctly.
As root
- make sure that the file /etc/ld.so.conf contains a line /usr/lib
- run /sbin/ldconfig
(This is for RedHat Linux. File names and location might differ with
other distributions.)
Hope this helps...
Ralph
- Re: EPICS R3.14 problem Andrew Johnson
- Re: EPICS R3.14 problem Ralph Lange
Re: EPICS R3.14 problem Eric Norum
<2002>
2025
2026
<2002>
2025
2026
