1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS R3.14 problem
To: Ralph Lange <[email protected]>
Cc: Krishna <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 07 Nov 2002 13:56:09 -0600
Ralph Lange wrote:
> locate libreadline
> it is showing that two packages installed at,
  >  /usr/lib/libreadline.so.4
  >  /usr/lib/libreadline.so.4.2
this readline library should be sufficient.
Vijayram,
I suspect it's looking for the static libreadline.a file, which is in a different RPM on Red Hat at least and is present on our systems here, but evidently not on yours (from your locate output above). If you can install the .a version you'll fix the problem sooner, but we need to fix the EPICS build system too as it's obviously *not* trying to use shared libraries here when it really should be (assuming you haven't changed the SHARED_LIBRARIES setting in configure/os/CONFIG_SITE.linux-x86.Common)
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
Re: EPICS R3.14 problem Ralph Lange
Prev: Re: EPICS R3.14 problem Ralph Lange
Next: RE: Extending MBBO? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS R3.14 problem Ralph Lange
