1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Extending MBBO?
To: "'[email protected]'" <[email protected]>
Date: Thu, 7 Nov 2002 14:01:53 -0600
Thanks for the replies regarding extending MBBO.
In my case I have a digital multimeter with 22 input channels.  I wanted an
medm screen with 22 radio buttons, so one and only one could be pressed at
once.  There does not seem to be a simple way to do this.
My solution was to have 3 MBBO records:
- channel_range selects "1-10" or "11-22"
- channel_1 selects "Ch1", "Ch2", ... "Ch10"
- channel_2 selects "Ch11", "Ch12", ... "Ch22"
There is an medm menu for channel_range that is always visible and selects
channel range 1-10 or 11-12.  Depending on the value of that menu item,
radio buttons for channels 1-10 or 11-12 are visible.  They occupy the same
location on the screen.
In my case the logic for the channel_1 and channel_2 MBBO records is done
using an SNL program, but a database could be used as well.
This solution works fine, and occupies less screen real estate than 22
buttons anyway.
Mark Rivers
Prev: Re: EPICS R3.14 problem Andrew Johnson
Next: Re: EPICS R3.14 problem Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Extending MBBO? Owens, PH (Peter)
Next: Use of AutoReply Ralph Lange
