1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS R3.14 problem
Cc: Krishna <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 7 Nov 2002 21:03:37 +0100
>>>>> "Andrew" == Andrew Johnson <[email protected]> writes:
  > the EPICS build system too as it's obviously *not* trying to use shared
  > libraries here when it really should be (assuming you haven't changed the
  > SHARED_LIBRARIES setting in configure/os/CONFIG_SITE.linux-x86.Common)
You probably mean STATIC_BUILD.
SHARED_LIBRARIES defines if a shared version of the libraries should be
built. (Built as opposed to used.)
Ralph
Re: EPICS R3.14 problem Ralph Lange
Re: EPICS R3.14 problem Andrew Johnson
Prev: RE: Extending MBBO? Mark Rivers
Next: Re: Linux seq compilation error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS R3.14 problem Andrew Johnson
Next: Re: EPICS R3.14 problem Eric Norum
