GOURNAY Jean-François DAPNIA wrote:
I am now trying to install the sequencer and I have the following error:
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi -pedantic -O3 -Wall -mcpu=pentium -fPIC -I.
-I.. -I../../../include/os/Linux -I../../../include
-I/home/sigx0/gournay/EPICS3.14/base/include/os/Linux
-I/home/sigx0/gournay/EPICS3.14/base/include ../seq_qry.c
.../seq_qry.c: In function `seqShow':
.../seq_qry.c:72: warning: void format, epicsThreadOSD arg (arg 2)
.../seq_qry.c:77: warning: void format, ELLLIST arg (arg 2)
.../seq_qry.c: In function `seqQueueShow':
.../seq_qry.c:275: structure has no member named `next'
The problem comes with seq-2.0.2 downloaded from SLAC. I run Red Hat 7.2.
I see the same problem here, and there even appears to be a solution
within the distribution itself - look for a file in the seq-2.0.2
directory called diff_%src%seq%seq_qry.c. After applying the reversed
change shown in that file the thing builds properly for me (but I haven't
tested it yet to see if it actually works).
Could the SEQ maintainer explain why that file is there, rather than
having been applied before creating the tar file?
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
- Linux seq compilation error GOURNAY Jean-François DAPNIA
Re: EPICS R3.14 problem Ralph Lange
RE: Linux seq compilation error Laznovsky, Michael
<2002>
2025
2026
<2002>
2025
2026
