1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linux seq compilation error
To: "'[email protected]'" <[email protected]>, "'Andrew Johnson'" <[email protected]>, GOURNAY Jean-François DAPNIA <[email protected]>
Cc: "Laznovsky, Michael" <[email protected]>
Date: Thu, 07 Nov 2002 17:12:47 -0800
Hello- this is a known problem; however, we've had no trouble compiling
it under Linux w/gcc 2.95.3 here at SLAC.
I pointed it out to Marty a while back and he replied thusly:
  > From: Marty Kraimer
  > Sent: Wednesday, May 08, 2002 6:02 AM
  > This is a fix that is needed for building against 3.13.6 and the NEXT
  > release of 3.14.
  > I am not sure this needs a new release from you. Wait until we are ready
  > for the next 3.14 release. For the next release I will make sure the sequencer
  > builds and works with exampleApp.
  > Marty Kraimer
In the meantime I plan to release Real Soon Now a version 2.0.3 on the SLAC
website that incorporates the fix (and also the recent documentation changes,
assuming I can find editable versions!).
Mike
Michael P. Laznovsky                           <mailto:[email protected]>
Application Software Developer, ESD                         ofc: (650) 926-2924
Stanford Linear Accelerator Center, MS-46                   fax: (650) 926-3515
2575 Sand Hill Road, Menlo Park CA 94025 USA     <http://www.slac.stanford.edu>
-----Original Message-----
Sent: Thursday, November 07, 2002 12:08 PM
To: GOURNAY Jean-François DAPNIA
Subject: Re: Linux seq compilation error
GOURNAY Jean-François DAPNIA wrote:
> I am now trying to install the sequencer and I have the following error:
> /usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -DOSITHREAD_USE_DEFAULT_STACK       -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
> -D_REENTRANT -ansi -pedantic  -O3  -Wall       -mcpu=pentium -fPIC   -I.
> -I.. -I../../../include/os/Linux -I../../../include
> -I/home/sigx0/gournay/EPICS3.14/base/include/os/Linux
> -I/home/sigx0/gournay/EPICS3.14/base/include         ../seq_qry.c
> .../seq_qry.c: In function `seqShow':
> .../seq_qry.c:72: warning: void format, epicsThreadOSD arg (arg 2)
> .../seq_qry.c:77: warning: void format, ELLLIST arg (arg 2)
> .../seq_qry.c: In function `seqQueueShow':
> .../seq_qry.c:275: structure has no member named `next'
> The problem comes with seq-2.0.2 downloaded from SLAC. I run Red Hat 7.2.
I see the same problem here, and there even appears to be a solution
within the distribution itself - look for a file in the seq-2.0.2
directory called diff_%src%seq%seq_qry.c.  After applying the reversed
change shown in that file the thing builds properly for me (but I haven't
tested it yet to see if it actually works).
Could the SEQ maintainer explain why that file is there, rather than
having been applied before creating the tar file?
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
Prev: Re: Linux seq compilation error Andrew Johnson
Next: Cexp 1.0_beta is released - yet another runtime loader for RTEMS Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Extending MBBO? Mark Rivers
