1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tcl/tk error
To: Lei Ge <[email protected]>
Cc: [email protected], Kazuro FURUKAWA <[email protected]>
Date: Fri, 08 Nov 2002 20:49:55 +0900
If I understand correctly, you are using tcl/tk through SADscript/Tk.
For some functions of Tcl, we need to load Tk first into SADscript,
as in
 In[1]:= w=Window[]
 *** SAD/Tkinter Version 1.0.8.14.4b 8/19/2002 ***
Out[1]:= DefineWidgetSpecific[Window,w,Epilog]
 In[2]:= StringReplace[Tcl["return $tk_version",String],("."->",")]
Out[2]:= "8,3"
"Window[]" will load Tk.  Or we may use "TclEval" instead of "Tcl"
as in
 In[1]:= StringReplace[TclEval["return $tk_version",String],("."->",")]
Out[1]:= "8,3"
Out[2]:= "8,3"
(After Tk is loaded, you may invoke any Tcl functions.)
>>> On Fri, 08 Nov 2002 16:21:44 +0800,  Lei Ge <[email protected]> wrote;
> Hello, everyone,
> For some special need I built tcl8.3.2 and tk8.3.2 on my Solaris 2.8
> workstation with a patch, and using gmake and gcc. But when applying this
> tcl/tk to an application, I got:
> > ???Tkinter::tclerror:  Error in Tcl: -1 in Tcl["return $tk_version",String]
> > ???General::wrongtype:  Argument must be Character-string in StringReplace[Tcl["return $tk_version",String],("."->",")]
> > ???Tkinter::tclerror:  Error in Tcl: -1 in Tcl["bind Entry <Key-Delete> {if [%W selection present] {    %W delete sel.first
> > sel.last     } else {%W delete [expr [%W index insert] - 1] insert}}"]
> > ???Tkinter::tclerror:  Error in Tcl: -1 in Tcl["bind Text <Key-Delete> {if [string compare [%W tag ranges sel] {}] {    %W delete
> > sel.first sel.last     } else {%W delete {insert -1 chars} insert}}"]
> >  Memory Full, request:  204360873 166887989  Infinity
> > Segmentation Fault (core dumped)
> Will anyone give me some help? Any reply is appreciated.
> Thanks,
> Ge Lei
Regards, Kazuro.
 Linac,  High Energy Accelerator Research Organization (KEK), Japan
tcl/tk error Lei Ge
Prev: Re: tcl/tk error Thomas Birke
Next: Interrupt callbacks in 3.14.0Beta for Linux John P. Quintana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
