Hi Kevin,
Unless you actually want to build VDCT you can simply download the
binaries and run them. Perhaps the instructions on the web site could be
clearer.
Go to
http://www.cosylab.com/visualdct/builds/VisualDCT/2.3.1240/index.html
Kick on "2.3.1240" under the "Distribution" heading.
Save the zip file somewhere convenient.
Unzip the zip file, to somewhere convenient. I made a "vdct" directory
in the "Program Files" directory and extracted to there.
You should then see a "2.3.1240" directory. In that you'll see a file
named "runScript".
Rename "runScript" to "runSript.bat" and execute it. VDCT should start.
You will need JVM 1.4.
Good luck.
John.
"Kevin M. Peterson" wrote:
> I am trying to get VDCT running on a Windows 98 machine that originally had
> none of the
> components that are required for VDCT. I have been following the direction
> on the following
> website:
> http://www.cosylab.com/visualdct/builds/VisualDCT/2.3.1240/doc/DOC-Java_Installation_and_Build_Process_of_VisualDCT.html
> I found the directions extremely difficult to follow due to a lack of
> important information. An
> example is the explanation of why 3rd party software is needed. It's nice
> to know that 3rd party
> software is needed for the build process and for program execution, but it
> would be significantly
> more helpful to have a list of the software that is needed for each.
> At other points in the documentation information was simply missing. In
> the third instruction
> of the "3. Eclipse Installation" section it says to define two variables
> but only one is mentioned.
> The fourth instruction of the same section says that the necessary Eclipse
> extensions are
> available on the Cosylab web page but I was unable to find them. Links to
> necessary pieces
> of software would be helpful.
> On the topic of links, in the "Dependencies" section of
> there is a link to what is supposedly VisualDCT-Common, but the link does
> not work. I had to
> search for it on google to find a site that had something that I could
> download. I ended up
> downloading version 1.2 of VisualDCT-Common.
> So with my complaints about the documentation aside, I still do not know
> how to get VDCT up
> and running. I have the Java 2 Platform, Standard Edition and the JUnit
> Testing Framework
> installed and working correctly. I have the other pieces of "required"
> software (Styler ANT Task,
> MySQL JDBC driver, VisualDCT-Common, Eclipse, and Apache Ant) installed but
> I do not know
> if they are installed correctly. When I run VisualDCT.jar VDCT appears to
> start. I am prompted
> to choose an Epics database and when I choose one, all my pretty windows go
> away and I'm
> left staring at my background. I'm pretty sure that isn't the desired
> behavior.
> Which software do I need to get VDCT running? Do I need to build VDCT or
> are the build instructions
> just provided in case I want a non-standard installation?
> Or better yet, how do I install VDCT if I know nothing about the software
> on which VDCT is dependent?
> This seems to be the question that the "Java installation and build process
> of VDCT" should answer,
> but since it fails to do so, I am left extraordinarily confused.
> Thanks for your time,
> The extraordinarily confused Kevin Peterson
- Re: VDCT installation and documentation problems... Till Straumann
- VDCT installation and documentation problems... Kevin M. Peterson
RE: libezca and EPICS-3.14 Jeff Hill
<2002>
2025
2026
<2002>
2025
2026
