1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: libezca and EPICS-3.14
To: "'Till Straumann'" <[email protected]>, "'Tech-talk'" <[email protected]>
Date: Wed, 4 Dec 2002 16:24:33 -0700
> CA.Client.Exception............................................
>      Warning: "Virtual circuit disconnect"
>      Context: "134.79.35.35:5064"
>      Source File: ../cac.cpp line 1809
>      Current Time: Wed Dec 04 2002 13:48:18.219267000
Do you know for certain that the "read command" is failing or are you
encountering the following situation?
In R3.14 beta 1 and beta 2 the ca client library will print the above
message if a connected channel still exists when you call
ca_task_exit(). To remain strictly backwards compatibility this message
is suppressed, only for this specific situation, in the latest version
of R3.14.
Does ezca block in ca_pend_io() when it is waiting for the "read
command" to complete? If so, then how long is the timeout which is
provided to ca_pend_io()?
Jeff
> -----Original Message-----
> From: Till Straumann [mailto:[email protected]]
> Sent: Wednesday, December 04, 2002 3:12 PM
> To: Tech-talk
> Subject: libezca and EPICS-3.14
> Hi.
> I discussed this briefly with Marty at JLAB. He suggested
> I should post to the list. I was not sure whether the
> EZCA library is supported under 3.14.
> Here's my problem:
> I have put together a CA interface for SCILAB (a nice open
> source tool a la matlab) who builds on top of libezca. Works
> fine with 3.13.
> Using 3.14_beta1, I can access (e.g. read using ezcaget) a PV
> into SCILAB without problem. An attempt to access the same PV
> a couple of minutes later fails, however, giving the following
> error:
> Strange enough, if I repeat the read command for a couple
> of times, it works again. Let some time expire and it again
> fails.
> And so on.
> Does somebody have an explanation or, yet better, a fix?
> -- Till
Re: libezca and EPICS-3.14 Till Straumann
Prev: Re: VDCT installation and documentation problems... John Maclean
Next: Re: VDCT installation and documentation problems... Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: libezca and EPICS-3.14 Till Straumann
Next: Re: libezca and EPICS-3.14 Till Straumann
