1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: libezca and EPICS-3.14
To: Tech-talk <[email protected]>
Date: Wed, 04 Dec 2002 14:12:18 -0800
Hi.
I discussed this briefly with Marty at JLAB. He suggested
I should post to the list. I was not sure whether the
EZCA library is supported under 3.14.
Here's my problem:
I have put together a CA interface for SCILAB (a nice open
source tool a la matlab) who builds on top of libezca. Works
fine with 3.13.
Using 3.14_beta1, I can access (e.g. read using ezcaget) a PV
into SCILAB without problem. An attempt to access the same PV
a couple of minutes later fails, however, giving the following
error:
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "134.79.35.35:5064"
    Source File: ../cac.cpp line 1809
    Current Time: Wed Dec 04 2002 13:48:18.219267000
Strange enough, if I repeat the read command for a couple
of times, it works again. Let some time expire and it again fails.
And so on.
Does somebody have an explanation or, yet better, a fix?
-- Till
RE: libezca and EPICS-3.14 Jeff Hill
Prev: Re: building capfast with EPICS R3.14.0beta2 Matthieu Bec
Next: VDCT installation and documentation problems... Kevin M. Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: libezca and EPICS-3.14 Jeff Hill
