Hi Kevin,
you should find an edb.def somewhere in epics extension/edif
then look at your CONFIG_SITE for definition of E2DB and such.
this is how it looks like here at Gemini (be carefull that's a 3.13
setup, but it probably adapts to 3.14)
E2DB = $(EPICS_EXTENSIONS)/bin/$(HOST_ARCH)/e2db
E2DB_SYSFLAGS = -ate -d $(EPICS_EXTENSIONS)/src/edif/lib/edb.def
cheers,
Matthieu
Kevin Tsubota wrote:
I'm having problems building capfast .sch files into .db files.
I'm using the DB rule and specify the .db I want built based on the
schematic name, in this case I want tnet.sch built and install as tnet.db.
However when I do this I get the following error:
mahaiula:tnetDev> gmake
perl /usr/local/epics/r3.14.0beta2/base/configure/tools/makeMakefile.pl
O.solaris-sparc-gnu ../../..
mkdir O.Common
gmake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
T_A=solaris-sparc-gnu install
gmake[1]: Entering directory
`/home/ktsubota/kroot/kss/epcom/unixIoc/dev/tnetDev/O.solaris-sparc-gnu'
gmake[1]: *** No rule to make target `../O.Common/tnet.substitutions',
needed by `../O.Common/tnet.db'. Stop.
gmake[1]: Leaving directory
gmake: *** [install.solaris-sparc-gnu] Error 2
mahaiula:tnetDev>
I've tried specifying "DB += tnet.edf" and this generates the .edf file
based on tnet.sch but also
goes ahead installs it into $(INSTALL_DB), it didn't convert the .edf to
.db.
I also specified both "DB += tnet.edf tnet.db" but that gives an error
saying it can't fine /edb.def.
Am I using the wrong rule? How do I tell the makefile to take a .sch file
and make and install a .db file?
Thank you.
Kevin Tsubota
California Association for Research in Astronomy
W.M. Keck Observatory
65-1120 Mamalahoa Hwy.
Kamuela, HI 96743
tel: (808) 885-7887
Matthieu Bec Gemini Observatory
Tel: +1 808 9742557 670 N. A'ohoku Place
Fax: +1 808 9359235 Hilo, Hawaii 96720, USA
- building capfast with EPICS R3.14.0beta2 Kevin Tsubota
libezca and EPICS-3.14 Till Straumann
<2002>
2025
2026
<2002>
2025
2026
