1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: building capfast with EPICS R3.14.0beta2
To: "tech-talk (E-mail)" <[email protected]>
Date: Wed, 4 Dec 2002 08:13:03 -1000
> I'm having problems building capfast .sch files into .db files.
> I'm using the DB rule and specify the .db I want built based on the
> schematic name, in this case I want tnet.sch built and install as tnet.db.
> However when I do this I get the following error:
> mahaiula:tnetDev> gmake
> perl /usr/local/epics/r3.14.0beta2/base/configure/tools/makeMakefile.pl
> O.solaris-sparc-gnu ../../..
> mkdir O.Common
> gmake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
> T_A=solaris-sparc-gnu install
> gmake[1]: Entering directory
> `/home/ktsubota/kroot/kss/epcom/unixIoc/dev/tnetDev/O.solaris-sparc-gnu'
> gmake[1]: *** No rule to make target `../O.Common/tnet.substitutions',
> needed by `../O.Common/tnet.db'.  Stop.
> gmake[1]: Leaving directory
> gmake: *** [install.solaris-sparc-gnu] Error 2
> mahaiula:tnetDev>
> I've tried specifying "DB += tnet.edf" and this generates the .edf file
> based on tnet.sch but also
> goes ahead installs it into $(INSTALL_DB), it didn't convert the .edf to
> .db.
> I also specified both "DB += tnet.edf tnet.db" but that gives an error
> saying it can't fine /edb.def.
> Am I using the wrong rule? How do I tell the makefile to take a .sch file
> and make and install a .db file?
> Thank you.
> Kevin Tsubota
> California Association for Research in Astronomy
> W.M. Keck Observatory
> 65-1120 Mamalahoa Hwy.
> Kamuela, HI  96743
> tel: (808) 885-7887
Re: building capfast with EPICS R3.14.0beta2 Matthieu Bec
Prev: Re: Problems with 3.13.7 and PPC604/MV2304 Andrew Johnson
Next: Re: building capfast with EPICS R3.14.0beta2 Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
