Hammonds, John wrote:
I have been working with a transition between R3.13.5 and
3.13.7. I finally got through problems with connecting with
Channel Access with the help of Jeff and Janet. Yesterday I
tried to boot a crate with an MV2304 board and find that I
cannot load iocCore. This does work with the MV167 and
MV172. Errors are shown below. I am using Tornado 2.02 on
Solaris 7 to compile everything. This does work if I drop
back to 3.13.5 with everything else the same. Any suggestions?
ld < iocCore
Relocation value does not fit in 24 bits.
To expand slightly on Geoff's reply, this occurs because you have more
than 32MB of RAM on your board. A full explanation is found at
http://www.aps.anl.gov/epics/modules/base/ppc.php#Relocation as are some
solutions. I think we've accepted that option 2 is the only really
sensible way to handle this.
Janet is adding some new target architectures to allow both short and long
call versions to be built in the same EPICS tree. Compiled PowerPC
binaries are something like 20% larger when using long calls and the
result will be slower (more instructions to execute and more cache misses
too), so we'd like the build system to allow a short call version to be
loaded by systems that only have 32MB.
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
- Problems with 3.13.7 and PPC604/MV2304 Hammonds, John
Re: Geoff Savage
building capfast with EPICS R3.14.0beta2 Kevin Tsubota
<2002>
2025
2026
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
