1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: libezca and EPICS-3.14
To: Jeff Hill <[email protected]>
Cc: "'Tech-talk'" <[email protected]>
Date: Wed, 04 Dec 2002 20:23:52 -0800
Having Stephanie next door pays off :-)
My application behaves like this:
ezcaGet();
/* user works; this can take minutes, hours, days */
   ezcaGet();
   /* second ezcaGet() fails if more than ~80sec expire
    * between the ezca calls
Steph pointed out that the CA library still needs to handle
beacons even when idle and recommended to initialize the
application's CA context with ca_enable_preemptive_callback.
As a (undocumented) side effect, this would result in beacons
being handled by one of the CA background threads.
(At least, this is what I recall from our conversation - if
not completely accurate, I'm to blame for misquoting)
Anyways, this helped, the disconnects are gone and I'm  happy
because I no longer need 3.13 around :-)
-- Till
PS: the app now does
ca_context_create(ca_enable_preemptive_callback);
    ezcaGet();
/* user works for hours */
    ezcaGet();
    /* SUCCESS */
Jeff Hill wrote:
CA.Client.Exception............................................
    Warning: "Virtual circuit disconnect"
    Context: "134.79.35.35:5064"
    Source File: ../cac.cpp line 1809
    Current Time: Wed Dec 04 2002 13:48:18.219267000
Do you know for certain that the "read command" is failing or are you
encountering the following situation?
In R3.14 beta 1 and beta 2 the ca client library will print the above
message if a connected channel still exists when you call
ca_task_exit(). To remain strictly backwards compatibility this message
is suppressed, only for this specific situation, in the latest version
of R3.14.
Does ezca block in ca_pend_io() when it is waiting for the "read
command" to complete? If so, then how long is the timeout which is
provided to ca_pend_io()?
Jeff
-----Original Message-----
Sent: Wednesday, December 04, 2002 3:12 PM
To: Tech-talk
Subject: libezca and EPICS-3.14
Hi.
I discussed this briefly with Marty at JLAB. He suggested
I should post to the list. I was not sure whether the
EZCA library is supported under 3.14.
Here's my problem:
I have put together a CA interface for SCILAB (a nice open
source tool a la matlab) who builds on top of libezca. Works
fine with 3.13.
Using 3.14_beta1, I can access (e.g. read using ezcaget) a PV
into SCILAB without problem. An attempt to access the same PV
a couple of minutes later fails, however, giving the following
error:
Strange enough, if I repeat the read command for a couple
of times, it works again. Let some time expire and it again
fails.
And so on.
Does somebody have an explanation or, yet better, a fix?
-- Till
RE: libezca and EPICS-3.14 Jeff Hill
Prev: Re: VDCT installation and documentation problems... Till Straumann
Next: Building 3.13Extensions with 3.14 Base Probelm Edwin du
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: libezca and EPICS-3.14 Jeff Hill
Next: RE: libezca and EPICS-3.14 Jeff Hill
