Thanks for your reply. Oops - I had forgotten the attachment, sorry -- Till Jeff Hill wrote: > 1) Be careful about using R3.14's new feature allowing preemptive > callback with EZCA. Being a legacy single threaded code, the EZCA > library probably isn't properly protected against CA callbacks occurring > preemptively from another thread, at any time, even when it is not > executing in a CA function. I guess it's not safe. > > 2) If the CA client library does not see the server's beacon then it > sends an "are you there" message to the server over TCP. It is supposed > to work (in preemptive callback mode or otherwise) in a way that if you > do not call ca_pend_event() very often and a UDP beacon is lost, then it > will still send the "are you there" message and will not disconnect > until ca_pend_event() is called again and the "are you there" has not > been replied to within a reasonable amount of time. > > 3) This disconnect message that you are seeing, assuming that it is not > the false message occurring only when the process calls ca_task_exit() I believe that not being the case. ezca never calls ca_task_exit(). BTW: I could distill a trivial test program (attached) to reproduce the problem. It essentially does: ezcaGet();
sleep(120);
ezcaGet();After about 1min, the message: Unable to contact CA repeater after 50 tries Silence this message by starting a CA repeater daemon appears (note that I _have_ a repeater running) when the 2min expire and the second ezcaGet() attempt is made, I finally get the message (2nd ezcaGet() fails): CA.Client.Exception...............................................
Warning: "Virtual circuit disconnect"
Context: "134.79.35.35:5064"
Source File: ../cac.cpp line 1809
Current Time: Thu Dec 05 2002 12:29:24.852541000
get_callback() : Virtual circuit disconnectNeither of these messages appears when I either enable the preemptive callback or when I use ezcaDelay() instead of sleep() (I suppose because the ezcaDelay() does ca_pend()). -- Till > and channels are still connected (that has been fixed after R3.14 beta > 2), could be a bug related to proper implementation of (2) above. > However you are using R3.14 beta one which was a very preliminary (and > certainly buggy) release of R3.14. Given that we are about to release > R3.13.1, then it would be very interesting (at least for me) to see if > the same problem exists with R3.14 beta 2 and ezca. > > Jeff > > > >>-----Original Message----- >>From: Till Straumann [mailto:[email protected]] >>Sent: Wednesday, December 04, 2002 9:24 PM >>To: Jeff Hill >>Cc: 'Tech-talk' >>Subject: Re: libezca and EPICS-3.14 >> >>Having Stephanie next door pays off :-) >> >>My application behaves like this: >> >> ezcaGet(); >> >> /* user works; this can take minutes, hours, days */ >> >> ezcaGet(); >> /* second ezcaGet() fails if more than ~80sec expire >> * between the ezca calls >> */ >> >>Steph pointed out that the CA library still needs to handle >>beacons even when idle and recommended to initialize the >>application's CA context with ca_enable_preemptive_callback. >>As a (undocumented) side effect, this would result in beacons >>being handled by one of the CA background threads. >>(At least, this is what I recall from our conversation - if >>not completely accurate, I'm to blame for misquoting) >> >>Anyways, this helped, the disconnects are gone and I'm happy >>because I no longer need 3.13 around :-) >> >>-- Till >> >>PS: the app now does >> >> ca_context_create(ca_enable_preemptive_callback); >> >> ... >> ezcaGet(); >> >> /* user works for hours */ >> >> ezcaGet(); >> /* SUCCESS */ >> >> >>Jeff Hill wrote: >> >>>>CA.Client.Exception.......................................... >>> >>.. >> >>>>... >>>> Warning: "Virtual circuit disconnect" >>>> Context: "134.79.35.35:5064" >>>> Source File: ../cac.cpp line 1809 >>>> Current Time: Wed Dec 04 2002 13:48:18.219267000 >>>>............................................................. >>> >>.. >> >>> >>>Do you know for certain that the "read command" is failing or >> >>are you >> >>>encountering the following situation? >>> >>>In R3.14 beta 1 and beta 2 the ca client library will print >> >>the above >> >>>message if a connected channel still exists when you call >>>ca_task_exit(). To remain strictly backwards compatibility >> >>this message >> >>>is suppressed, only for this specific situation, in the >> >>latest version >> >>>of R3.14. >>> >>>Does ezca block in ca_pend_io() when it is waiting for the >> >>"read >> >>>command" to complete? If so, then how long is the timeout >> >>which is >> >>>provided to ca_pend_io()? >>> >>>Jeff >>> >>> >>> >>>>-----Original Message----- >>>>From: Till Straumann [mailto:[email protected]] >>>>Sent: Wednesday, December 04, 2002 3:12 PM >>>>To: Tech-talk >>>>Subject: libezca and EPICS-3.14 >>>> >>>>Hi. >>>> >>>>I discussed this briefly with Marty at JLAB. He suggested >>>>I should post to the list. I was not sure whether the >>>>EZCA library is supported under 3.14. >>>> >>>>Here's my problem: >>>> >>>>I have put together a CA interface for SCILAB (a nice open >>>>source tool a la matlab) who builds on top of libezca. Works >>>>fine with 3.13. >>>>Using 3.14_beta1, I can access (e.g. read using ezcaget) a PV >>>>into SCILAB without problem. An attempt to access the same PV >>>>a couple of minutes later fails, however, giving the >>> >>following >> >>>>error: >>>> >>>>CA.Client.Exception.......................................... >>> >>.. >> >>>>... >>>> Warning: "Virtual circuit disconnect" >>>> Context: "134.79.35.35:5064" >>>> Source File: ../cac.cpp line 1809 >>>> Current Time: Wed Dec 04 2002 13:48:18.219267000 >>>>............................................................. >>> >>.. >> >>>>..... >>>> >>>>Strange enough, if I repeat the read command for a couple >>>>of times, it works again. Let some time expire and it again >>>>fails. >>>>And so on. >>>> >>>>Does somebody have an explanation or, yet better, a fix? >>>> >>>>-- Till >>> >>> > > #include <cadef.h>
#include "ezca.h"
#include <assert.h>
#include <stdio.h>
static void
usage(char *n)
fprintf(stderr,"usage: %s PV\n",n);
int
main(int argc, char **argv)
int n=1,i;
double db;
if ( argc<2 ) {
usage(argv[0]);
exit(1);
// assert(ECA_NORMAL == ca_context_create(ca_enable_preemptive_callback));
for ( i=1; i>=0; i-- ) {
if ( ezcaGet(argv[1], ezcaDouble ,n,&db) ) {
fprintf(stderr,"ezca error");
exit(1);
printf("%s: %g\n",argv[1],db);
if ( i )
#if 0
ezcaDelay(120.);
#else
sleep(120);
#endif
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
