Benjamin Franksen wrote:
Jim Thomas wrote:
Consider a select record with SELM == "Specified" (SELECTED in the code).
The select record initializes non-constant inputs to 1e+30 .
Does anyone know the rationale behind this (IMHO rather strange)
initialization?
Why this (very large?) number?
It's been a long time since this was done so the following is just a guess.
Looking at the algorithms for SELECT_HIGH, SELECT_LOW, SELECT_MEDIAN the code
has to know if a fields was never given a value. For some reason the value 1e+30
was chosen to represent "never given a value". What else could be used? Big
problem unless IEEE floating point is assumed. Today perhaps a valid assumption
(even today what about VAX and alpha?). 12 years ago this assumption was not
considered safe to make.
Why - if deemed necessary or at least useful - is initialization not
done in selRecord.dbd, but somewhat hidden inside selRecord.c?
Since the code for the algorithm is hidden in the code why not also hide the
initization in the code? At least it all appears in one source module.
Ben
Marty
- select record versus dbpr() versus SPARC (at least) Jim Thomas
- Re: select record versus dbpr() versus SPARC (at least) Benjamin Franksen
jdct run-time error M.C.Shao
<2002>
2025
2026
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
