Eric Norum wrote:
On Thursday, December 12, 2002, at 02:44 AM, Edwin wrote:
Dear all:
I have finished building RTEMS boot images with EPICS 3.14 on
Linux, Host and client are both pc386.
While when I am trying to boot the IOC through BOOTP, my IOC
stuck when loading the boot image "example.bt".
I wrote the /etc/bootptab file as follows:
client1:hd=/epics/client1/bin:\
:vm=auto:ip=166.111.32.246:td=/tftpboot:\
:ht=ethernet:ha=0000ECD01FC7:\
:bf=example.bt:rp=/boot/client1/root
I download a bootstrap PROM image from www.rom-o-matic.net,
which find my boopd service on my host pc successfully
and start to download the boot image 'example.bt'. Screen prints:
.Me: 166.111.32.246, Server: 166.111.32.244
Loading 166.111.32.244:/epics/client1/bin/example.bt ...(NBI)...
I believe that the 'NBI' means 'non-bootable image'.
My 2 cents:
Hmm - etherboot uses the term NBI also; there it means 'Net Boot Image'
which would indicate that it indeed could be the correct image (with
the startup stuff added).
-- T.
From this error
message I'm guessing that you copied the executable EPICS application
(bin/RTEMS-pc386/example) to the TFTP server (....../bin/example.bt).
The rom-o-matic network boot ROMS however require a short 16-biit
startup section of code to be prepended to the EPICS application.
Here's the script which I use to do this. I called it makeBootImage and
run it as
makeBootImage bin/RTEMS-pc386/example
to produce example.bt which can be copied to the TFTP server.
#!/bin/sh
set -ex
case "$#" in
1) ;;
*) echo "Usage: $0 file[.exe]" >&2 ; exit 1 ;;
esac
n=`basename "$1" .exe`
code=2
trap 'rm -f /tmp/jnk$$.bin ; exit $code' 0 1 2 3
i386-rtems-objcopy --output-target=binary "$1" /tmp/jnk$$.bin
/opt/rtems/i386-rtems/pc386/build-tools/bin2boot "$n.bt" 0x00097E00
/opt/rtems/i386-rtems/pc386/lib/start16.bin 0x00097C00 0 /tmp/jnk$$.bin
0x00100000 0
code=0
- Re: Booting RTEMS IOC problem Eric Norum
<2002>
2025
2026
<2002>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
