I have listened to my NIC, using tcpdump, through which I could find out
that
there are only 2k bytes translated via tftp udp port.
15:13:16.193469 166.111.32.246.2001 > tu032244.tsinghua.edu.cn.tftp: 51
RRQ "/epics/client1/bin/example.bt"
15:13:16.194699 tu032244.tsinghua.edu.cn.32887 > 166.111.32.246.2001:
udp 15 (DF)
15:13:16.194757 166.111.32.246.2001 > tu032244.tsinghua.edu.cn.32887:
udp 4
15:13:16.194843 tu032244.tsinghua.edu.cn.32887 > 166.111.32.246.2001:
udp 1436 (DF)
15:13:16.195150 166.111.32.246.2001 > tu032244.tsinghua.edu.cn.32887:
udp 4
15:13:16.195198 tu032244.tsinghua.edu.cn.32887 > 166.111.32.246.2001:
udp 1436 (DF)
I have tried hello.bt also, the result is the same.
I just chose my Ethernet card type as Realtek8139, and replaced BOOTP to
DHCP when configuring the rom-o-matic image, other setting is default.
BTW I have tried to boot 'example' with grub, the image does boot up,
following is the screen catch:(I have configured ne2000 net driver)
Initialized console on port CONSOLE
********** Initializing network *******
network device 'ne1' <FF:FF:FF:FF:FF:FF> initialized on port 0X300, irq
5
bootpc_init: using network interface 'ne1'
Bootpc testing starting
Bootpc hw address is ff:ff:ff:ff:ff:ff
BOOTP timeout for server 0xffffffff
seems it cannot find my bootpd server.
Thanks for replying...
Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Bug on Pentium IOC Bernd Schoeneburg
<2002>
2025
2026
Re: Booting RTEMS IOC problem Edwin du
hi 黄松
<2002>
2025
2026
