1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building 3.13Extensions with 3.14 base Problem.
To: Jim Thomas <[email protected]>
Cc: [email protected]
Date: Fri, 13 Dec 2002 14:16:08 -0600
Jim Thomas wrote:
"Andrew" == Andrew Johnson <[email protected]> writes:
Andrew> Personally I think that on Linux at least we should be embedding Andrew> the paths to the shared libraries into those binaries that use Andrew> them. I have this working, and will see if I can persuade Janet Andrew> to accept it for R3.14.1
If possible, please make it "easy" to put a different target path in
CONFIG_SITE_whatever for those of us who copy the installation elsewhere.
For the up-coming R3.14.1 release Janet has changed the linux-x86 default to build static libraries - configure/os/CONFIG_SITE.Common.linux-x86 has to be edited on installation to set SHARED_LIBRARIES=YES. However I have also added another setting to that file called SHRLIB_SEARCH_DIRS which is a list of application tops that are included in the runtime search path for shared libraries in the executables. In R3.14.1 this is only for Linux, but the approach could be generalized and added to other architectures if desired. For building extensions against R3.14.1 you would need to add the absolute path to your extensions top to this variable in CONFIG_SITE.Host.Linux
- Andrew
A: No, see http://www.netmeister.org/news/learn2quote.html
Q: Should I include quotations after my reply ?
Building 3.13Extensions with 3.14 base Problem. Edwin du
Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Prev: hi 黄松
Next: RE: Booting RTEMS IOC problem Edwin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Next: Re: my base download account cann't use M.C.Shao
