1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS exmaple application problem
To: "Eric Norum" <[email protected]>
Cc: "Tech-talk" <[email protected]>
Date: Thu, 16 Jan 2003 22:50:40 +0800
hi,
I am booting the EPICS example application on  i386-rtems target with a new rtl8139 driver. The driver has been tested successfully.
when "starting the application" during booting process, an error was delivered, the error message is:
filename="../dbLexRoutines.c" line number=238
I/O error dbRead opening file db/dbSubExample.db
Starting iocInit
iocInit:All initilization complete
epics>
As above indicate, all initilization complete, and I could type the shell command, such as dbl, dbpr, etc.
But when I use medm to connect to the records of the ioc, exception was encounterd.The following are messages that appear in the medm message window:
Thu Jan 16 21:47:10 CST 2003
medmCAExceptionHandlerCb: Channel Access Exception:
  Channel Name: Unavailable
  Native Type: Unavailable
  Native Count: 0
  Access: Unavailable
  IOC: Unavailable
  Message: Virtual circuit disconnect
  Context: 166.111.32.240:5064
  Requested Type: TYPENOTCONN
  Requested Count: 0
  Source File: ../cac.cpp
  Line number: 1532
"166.111.32.240" is the ip address of the ioc.
 What's the reason?any suggestions are appreciated. Thanks in advance.
Shao Mingchao
Engineering Physics Department
Tsinghua University
Beijing,100084,China
Re: EPICS exmaple application problem Eric Norum
RE: EPICS exmaple application problem Jeff Hill
Prev: Re: CAN bus and PPC processors John Maclean
Next: Re: EPICS exmaple application problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
