1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS exmaple application problem
To: "M.C.Shao" <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 16 Jan 2003 09:01:15 -0600
"M.C.Shao" wrote:
> hi,
> I am booting the EPICS example application on  i386-rtems target with a new rtl8139 driver. The driver has been tested successfully.
> when "starting the application" during booting process, an error was delivered, the error message is:
> filename="../dbLexRoutines.c" line number=238
> I/O error dbRead opening file db/dbSubExample.db
> Starting iocInit
> iocInit:All initilization complete
> epics>
> As above indicate, all initilization complete, and I could type the shell command, such as dbl, dbpr, etc.
> But when I use medm to connect to the records of the ioc, exception was encounterd.The following are messages that appear in the medm message window:
> Thu Jan 16 21:47:10 CST 2003
> medmCAExceptionHandlerCb: Channel Access Exception:
>   Channel Name: Unavailable
>   Native Type: Unavailable
>   Native Count: 0
>   Access: Unavailable
>   IOC: Unavailable
>   Message: Virtual circuit disconnect
>   Context: 166.111.32.240:5064
>   Requested Type: TYPENOTCONN
>   Requested Count: 0
>   Source File: ../cac.cpp
>   Line number: 1532
> "166.111.32.240" is the ip address of the ioc.
>  What's the reason?any suggestions are appreciated. Thanks in advance.
Does the "db/dbSubExample.db" file exist on your TFTP server?  Is it
readable by all?
Eric Norum <[email protected]>
Advanced Photon Source
(630) 252-4793
EPICS exmaple application problem M.C.Shao
Prev: EPICS exmaple application problem M.C.Shao
Next: RE: EPICS exmaple application problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
