"screen" is a unix program that may not be on your system but should be easily available. Our sysadmin people installed it for me very quickly. It allows you to detach the screen from the ioc without killing the ioc. You can of course reattach the screen later. screen is a program with many options, just consult the man page! However some commands that I've found useful are: (To simplify things I've assumed "myioc" is a script to start the ioc in the usual manner) screen myioc - this will start the ioc attached to a screen. <ctl>a <ctl>d will detach the screen, leaving the ioc running. screen -ls - will list the active screen sessions screen -r pid.tty.hostname - will reattach to the ioc screen. ssh -t pid.tty.hostname "screen -R" - reattaches to a screen on a remote machine (not sure this is the exact syntax for this one) screen -d -m myioc - will start the ioc in detached mode <ctl>a d - detaches screen from ioc I've found this to be a really neat tool. It even captures the console output when your screen is detached and you see it when you reattach. I have a couple of test stands running for our power supply group using this technique. There are issues of how you handle multiple iocs on one machine that I haven't had to consider yet. How do you make sure you shut down the correct ioc for example? I hope this helps. John. Kevin M. Peterson wrote:
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
