1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Running iocsh in the background
To: tech-talk <[email protected]>
Cc: "Kevin M. Peterson" <[email protected]>
Date: Thu, 30 Jan 2003 11:17:39 +0100
Kevin M. Peterson wrote:
I have a Linux IOC and I am using the main function from R3.14.1's example App. After the IOC is initialized iocsh left in "interactive mode" just like the App. Dev. Guide describes.
Unfortunately, "shutting down" the Linux IOC dangerously
easy.  It isn't necessary to type the "exit" command; Closing
the terminal window or pressing Ctrl-C do the job with even
less effort.
Is it possible to start the Linux IOC and have it run in the
background?  The Linux IOC seems to be missing the
"non-interacting mode" that all of the vxWorks IOCs have.
I have written a small tcl program (see attachment), that acts as a box for a shell (e.g. a Linux IOC) to run it in the background. Terminals programs can connect via TCP-IP (e.g. telnet). When the shell dies, it will be restarted automatically.
usage: shellbox.tcl <TCP-port> <shellcommand> &
It is a quick an simple tool, thus there is no security. Everyone can log in and all input is merged to stdin of the shell. All stdout and stderr is distributed to everyone who is logged in.
To make live easier, I have also written a script (iocsh, attached), that creates a startup script on the fly from its command line arguments and starts a Linux IOC. To use it, you will have to adjust the pathnames in the script :-(
Best regards
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Attachment: shellbox.tcl
Description: Tcl script
#!/bin/bash
if [ "$1" = -h ]
then
  echo "usage: iocsh [files]"
  echo "start an EPICS iocsh and load files"
  echo "recognized filetypes: *.db *.template *.subs *.dbd"
  echo "after *.db and *.template, you can specify substitutions with macro=value"
  echo "if a file is @filename, more arguments are read from filename"
  echo "all other files are taken as scripts to source"
  exit
fi
if [ "$1" = -v ]
then
  echo "iocsh by Dirk Zimoch"
  echo '$Source: /cvs/CVSROOT/UTILITIES/scripts/sh/iocsh,v $'
  echo '$Revision: 1.5 $'
  echo '$Date: 2002/12/19 08:55:23 $'
  exit
fi
export LD_LIBRARY_PATH=/devl/epics3.14.0.beta1/base/lib/linux-x86:$LD_LIBRARY_PATH
startup=$(mktemp /tmp/iocstartup.XXXXXX)
function loadFiles () {
while [ "$#" -gt 0 ]
do
  file=$1
  case $file in
    ( @* )               loadFiles $(cat ${file#@}) ;;
    ( *.db | *.template) subst=""
                         while [ "$#" -gt 1 ]
                         do
                            case $2 in
                                ( *=* ) subst="$subst,$2"; shift ;;
                                ( * )   break ;;
                            esac
                         done
                         echo "dbLoadRecords (\"$file\", \"${subst#,}\")" ;;
    ( *.subs | *.subst ) echo "dbLoadTemplate (\"$file\")" ;;
    ( *.dbd )            echo "dbLoadDatabase (\"$file\")" ;;
    ( * )                echo "< $file" ;;
  esac
  shift
done
echo "dbLoadDatabase /devl/epics3.14.0.beta1/APPS/EPS/dbd/example.dbd"
echo "registerRecordDeviceDriver pdbbase"
loadFiles $*
echo "iocInit"
} >> $startup
trap "rm -f $startup" EXIT
softioc $startup 2>&1
Running iocsh in the background Kevin M. Peterson
Prev: RE: Building VxWorks Boot Rom on Linux Singleton, SJ (Stephen)
Next: Re: Can't build the CMLOG under Tornado 2.0 for mv162, ppc etc. (fwd) Vladis Korobov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Running iocsh in the background John Maclean
Next: RE: Running iocsh in the background Rarback, Harvey
