1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Commercial RTOS to replace vxWorks
Cc: john sinclair <[email protected]>, tech talk <[email protected]>
Date: Fri, 21 Feb 2003 13:17:03 -0800
Andrew Johnson wrote:
john sinclair wrote:
Are there any plans to move toward a less expensive RTOS replacement for
vxWorks? I am interested in RTEMS but would also like to be able to
use a commercial product (without having to put up with Wind River).
RTEMS is available as a commercial product - you can pay oarcorp for support if you don't want to do everything yourself. Currently that's the leading alternative to vxWorks for IOCs with real hardware interfaces, although I'm personally interested in Jaluna, an open source (but also commercially supported) derivative of ChorusOS. It shouldn't be very hard to write the OSI routines to get EPICS running on Jaluna, which provides full Posix realtime support
RTEMS also supports the Posix API.
Unfortunately, my performance evaluation software had a bug
which resulted in apparently inferior latency figures
when using the POSIX API.
Repeated tests with the corrected benchmarking software
yielded the same low latencies measured when using
the native API.
-- Till
and a choice of 3 memory models, although nobody's doing this yet. http://www.jaluna.com/
- Andrew
Commercial RTOS to replace vxWorks john sinclair
Re: Commercial RTOS to replace vxWorks Andrew Johnson
Prev: Re: Commercial RTOS to replace vxWorks Andrew Johnson
Next: Re: Commercial RTOS to replace vxWorks Christopher A. Larrieu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
