Hi John,
Isn't the INPC field of the calc record an input link to the C field?
I would have assumed that you need to do the put to
"gppd0A:GasC:g1calc.C".
I guess the put to "gppd0A:GasC:gas1tol" works because you are writing
to the VAL field of the AI and then this is being pulled into field C
of the calc via the input link INPC when the calc processes.
Cheers,
Andy
On Tue, 25 Feb 2003, Hammonds, John P. wrote:
> I have an application running on an IOC. This application reads setup
> information for an experiment out of a file and then does a ca_put (C
> language call on IOC) to put values into record fields. I was recently
> trying to do a put to the INPC field of a record
> (gppd0A:GasC:g1calc.INPC) and keep getting an ECA_PUTFAIL error on the
> ca_put. The associated ca_search seems to go fine. Also, caput
> (extensions program on the host) has no problem putting values into this
> field.
> When I switch the database to have an ai record feed the INPC and do a
> caput to the ai record (gppd0A:GasC:gas1tol) I have no problems.
> Does anyone have any ideas of why the first method does not work?
> Thanks,
> John Hammonds
Observatory Sciences Limited Email: [email protected]
William James House Tel: 44 - (0)1223 - 508259
Cowley Road Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK http://www.observatorysciences.co.uk
- ca_put on an IOC Hammonds, John P.
RE: Serial driver for Linux Martin Pieck
Long expressions using MAX and MIN in CALC fields Redman, Russell O.
<2003>
2025
2026
<2003>
2025
2026
